Ignition Locked Up - Nissan Titan Forum
Titan FAQ & How to Area This area servers as a holding place for all FAQ entires, and Howto Articles.
post #1 of 13 (permalink) Old 05-09-2009, 11:59 AM Thread Starter
iTrader Score: 0 reviews
Ignition Locked Up
Need some help. After simply replacing a fog lamp bulb, my steering wheel is locked up and my ignition won't turn at all. I tried following the manual's instructions for unlocking the steering wheel to no avail. Any ideas on how to get it unlocked? Has anybody else had this problem?
It's a 2004 crew cab LE. Long time reader - first time poster.
Thanks for your help!
Havey81 is offline
Advertisement
post #2 of 13 (permalink) Old 05-09-2009, 12:07 PM
Re: Ignition Locked Up
Welcome to TT. I had the same happen. I don't think it has anything to do with changing a bulb. The salesman said I had parked it in a bind. Had to shake the steering wheel back and forth....hard and that freed the ignition up. Also, he said rocking the vehicle would work. Good luck.
bmbroker is offline
The Following User Says Thank You to bmbroker For This Useful Post:
Havey81 (05-09-2009)
post #3 of 13 (permalink) Old 05-09-2009, 12:56 PM Thread Starter
That worked! I was apparently just "jiggling" the steering wheel too lightly - a couple good hard shakes and it freed up.
To clarify on the lamp, I had disconnected the battery to change it and wondered if that might have impacted it. But, more than likely I just bumped and locked the steering column.
Thanks for your quick response!
Havey81 is offline
post #4 of 13 (permalink) Old 05-13-2009, 09:53 AM
I also have the ignition locked up. I tried to shake the steering wheel back and forth as hard as I can, but no luck. Does anyone have another idea? Thanks
PADDY49 is offline
post #5 of 13 (permalink) Old 05-14-2009, 06:09 AM Thread Starter
just to clarify - you need to turn the key while turning the steering wheel as well.
Havey81 is offline
The Following User Says Thank You to Havey81 For This Useful Post:
PADDY49 (05-15-2009)
post #6 of 13 (permalink) Old 05-14-2009, 06:14 AM
mcginkleschmidt's Avatar
Oops!
LOL, it that doesn't work then pull out the sledge hammer!
mcginkleschmidt is offline
The Following User Says Thank You to mcginkleschmidt For This Useful Post:
post #7 of 13 (permalink) Old 05-14-2009, 06:15 AM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
Good point Havey. My experience is that if it's "stuck" then you need to pull the steering wheel steadily to one side and then turn the key.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #8 of 13 (permalink) Old 05-14-2009, 08:00 AM
push the brake right to the floor, wiggle the gearshift while trying to turn the key. I had mine lock up at the mall and nothing worked so I called Nissan Canada and they told me sometimes if you push the lock buttons wrong it will lock down the wheel into safe mode. Worked for me. Good luck.
42772 is offline
The Following User Says Thank You to 42772 For This Useful Post:
post #9 of 13 (permalink) Old 05-14-2009, 06:35 PM
mp_cs's Avatar
For what reason would you disconnect the battery?
mp_cs is offline
post #10 of 13 (permalink) Old 05-15-2009, 05:06 AM
Thank you all so much for all your suggestions. I finally had to call my mechanic and even he couldn't get it to release. Luckily, it is under warranty, so the dealer towed it away last night. It was either that or the sledge hammer! lol
I'll let you know if there is anything else that could have been done.
PADDY49 is offline
post #11 of 13 (permalink) Old 05-15-2009, 06:22 AM
Hi again.
I forgot to mention the fact that I contacted Nissan with my question about the ignition lock. I explained it all to the "live chat". After I entered my question, it asked me how much I wanted to "pay for the tech's answer" The minimum "cost" was $9.00...what!! I again want to thank this forum for all your help--at no cost!
PADDY49 is offline
post #12 of 13 (permalink) Old 05-15-2009, 06:33 AM
Sooo tempting lol
PADDY49 is offline
post #13 of 13 (permalink) Old 05-15-2009, 06:41 AM
That "so tempting" post was for mcginkleschmidt-- and boy was I tempted!
lol
PADDY49 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
DE Schools locked down... 54warrior Off-Topic Discussion 9 03-20-2009 05:44 PM
Titan Locked Me Out??? sdnicker2000 Titan General Discussion 24 02-13-2009 05:55 AM
Keep those tailgates locked! Cmayer31 Titan General Discussion 33 11-23-2008 09:37 AM
You may post new threads
You may post replies
