TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 05-04-2004, 04:10 PM   #1 (permalink)
1BadTitan's Avatar
DIY.........Key Fob Programming
I tried it, it works. First you need all of the transmitters ready because you have to clear the code and that will erase the existing codes programmed.
Enter car, close all doors. Insert and remove key from ignition 6 times within 10 seconds. The hazard lights will flash to confirm original code has been erased. Turn the ignition to the ACC position. Press any button on the first transmitter. Hazard lights will flash to confirm programming. To enter additional transmitters, unlock then lock the doors using the power lock switch on the drivers door. Press any key on the second transmitter, the hazard lights will flash to confirm programming. Repeat the unlock then lock step to program additional transmitters. When finished, open drivers door, then remove key. You can have a max. of 4 transmitters per car.
[color=Blue]1BadTitan
The Following 3 Users Say Thank You to 1BadTitan For This Useful Post:
oceanglory28 (12-06-2009), TitanBlue (06-12-2010), willjames007 (08-22-2009)
Advertisement
Old 03-27-2009, 01:28 AM   #2 (permalink)
Re: Key Fob Programming
THIS SHOULD BE A STICKY.
People sell these directions on e-bay and dealers make you pay to set up your key fob.
I followed these direstions and programed the key fob I just bought from a TT member. It took about 10 seconds. Thanks alot.
GREAT WRITE UP!!
-Eric
millar1982 is offline   Reply With Quote
Old 03-27-2009, 05:01 AM   #3 (permalink)
themaildude's Avatar
Good info. Thanks for the write-up.
IRC CREW MEMBER
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 03-27-2009, 07:49 AM   #4 (permalink)
n2titan's Avatar
Great post.
I recently purchased a keyless entry pad and after programming that, both of my key fobs stopped working. I did the steps above and got all three devices working.
n2titan is online now   Reply With Quote
Old 03-27-2009, 09:43 AM   #5 (permalink)
is there a way to program just a key by doing this? I only have 1 key for my truck and the dealer wants $30 for the key and $120 top program it.
dean29 is offline   Reply With Quote
Old 03-28-2009, 11:21 PM   #6 (permalink)
MoValleyTitan's Avatar
Get another key and then reprogram both keys by using the above instructions.
MoValleyTitan is offline   Reply With Quote
Old 04-04-2009, 12:18 PM   #7 (permalink)
Copied and pasted to word for future reference. Thank you.
amiabledave50 is offline   Reply With Quote
Old 04-04-2009, 03:36 PM   #8 (permalink)
baseballfanz's Avatar
The key fob is easy, the actual "chipped" key you need a Consult device to do.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 05-31-2009, 01:24 PM   #9 (permalink)
Machado7's Avatar
I love this forum. The guys here have saved me so much $. Just used this procedure to program my "broken" FOB. THanks.
I am willing to host a forum party in Charleston, SC with what I have saved. Let me know if the interest is great enough.
Machado7 is offline   Reply With Quote
Old 05-31-2009, 06:40 PM   #10 (permalink)
O-FiveCC's Avatar
2005 Nissan Titan - Free Keyless Remote Fob Entry programming instructions, procedures for all automotive vehicles
I used this to program my Key Fob I bought off ebay. My old one would only work sometimes. It would usually only work after the truck had been sitting a while. Got a new one and programmed it a couple weeks ago, now it's doing it again. I wonder what is going wrong since I know its not the Key Fobs...maybe I should start a thread
Trans-Go reprogramming kit, JBA w/ 22" Mag, 07 intake, Detroit Tru-Trac, Nismo SS gauges, DDM HIDs (headlights and fogs, 8k), 9" TV, tinted tails, headlight mod, Graphite OEM 20's wrapped in Yokohama Parada Spec-X's, Armaden LED's all over, 2" Springtech shackles, Armada airdam
Going...Going....
O-FiveCC is offline   Reply With Quote
Old 07-13-2009, 07:16 PM   #11 (permalink)
decypher44's Avatar
Yet another fine example of how TT has come to save the day. I've been having a long road of bad luck in my life lately. This is at least one thing I no longer have to worry about. Thanks!!!
04 Titan 4x2 SE KC, Smoke, Magnaflow Single Exhaust, 05 Diff Cover, Stillen VKPro, AEM Brute Force w/DRYFLOW, Custom Painted Engine Cover , Sylvania Silverstars, Rhino Bedliner, Nissan Bug Smacker, Sirius Starmate 5 and iPod (AUX), Sony xplod, 2 x 10" JL 0, and a locking gas cap
decypher44 is offline   Reply With Quote
Old 07-21-2009, 06:58 AM   #12 (permalink)
I have an XE. Can't get the hazard lights to flash. I'm assuming it has the keyless entry "brain". What's my problem?
valandjer is offline   Reply With Quote
Old 07-21-2009, 08:45 AM   #13 (permalink)
beason's Avatar
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
do the xe's have keyless? do the doors lock/unlock? does the horn honk?
*06 Galaxy Black LE Crew Cab BT. *Air box mod *Armada air dam *Aries stainless step rails *Power Acoustik REACT1-1100 Class D2 1100-Watt Mono Amplifier with dual 10" kicker cv-r subs *Dick Cepek DC-1 18" chrome wheels *Flowmaster 50 dual in/out dumped *LED "mood" light *LED interior lights *2deg timing advance *Bully dog tuned *Advantage Torza Top folding bed cover *Jet Tech mod *Power tail gate lock *Frozen rotors with Hawk LTS pads *Titanium shifter knob (adds at least 25hp)
Soon to have: 2" drop shackles, tinted tails, CAI.
beason is offline   Reply With Quote
Old 07-21-2009, 12:51 PM   #14 (permalink)
It has power locks that can all be unlocked from the drivers door. The horn does not beep when I lock all the doors from the drivers door.
Old 07-21-2009, 01:10 PM   #15 (permalink)
O-FiveCC's Avatar
It worked on my XE with keyless entry...You can make the horn honk or not honk when you lock it if you hold the lock/unlock buttons down at the same time for a few seconds. Follow the instructions on the link I posted above, it worked for me, if it doesn't work for you then I don't know what to tell you. I think you have to be very deliberate and having the timing down pretty good for it to work, although I did it on my second try
Going...Going....
