Old 05-04-2004, 04:10 PM   #1 (permalink)
1BadTitan's Avatar
DIY.........Key Fob Programming
I tried it, it works. First you need all of the transmitters ready because you have to clear the code and that will erase the existing codes programmed.
Enter car, close all doors. Insert and remove key from ignition 6 times within 10 seconds. The hazard lights will flash to confirm original code has been erased. Turn the ignition to the ACC position. Press any button on the first transmitter. Hazard lights will flash to confirm programming. To enter additional transmitters, unlock then lock the doors using the power lock switch on the drivers door. Press any key on the second transmitter, the hazard lights will flash to confirm programming. Repeat the unlock then lock step to program additional transmitters. When finished, open drivers door, then remove key. You can have a max. of 4 transmitters per car.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
