Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan FAQ & Howto Area
User Name
Password
Dash Air Bag Sensor Reset - being discussed at Nissan Titan Forums in the Titan FAQ & Howto Area section.
Old 11-21-2004, 06:18 PM   #16
KHShapiro
awesome thank you
04 Titan Crew Cab SE Smoke
68 PT Camaro
KHShapiro is offline   Reply With Quote
Old 11-25-2004, 03:01 AM   #17
SeaRider
When all else failed, disconnect the battery. (You should disconnect the battery everytime you are working with anything which has SRS related for safety reason anyway.)
SeaRider is offline   Reply With Quote
Old 11-25-2004, 04:27 AM   #18
mlica_7
I took mine to the dealer. It took them 3 tries to fix it. THey finally had to replace some kind of cable that was shorting out.
mlica_7 is offline   Reply With Quote
Old 12-11-2004, 07:25 PM   #19
rfrench102
Originally Posted by rrumaner
This should be in the FAQ if it is not already.
I love you man!!! It worked!!! Pics tomorrow!!!
rfrench102 is offline   Reply With Quote
Old 08-21-2005, 01:19 PM   #20
donstitan
Finally
Thanks For The Excellent Post..have Been Driving Around With That Light Flashing And Didnt Want To Lay It Up At The Dealer. Ran Out After Reading This Post And It Worked Like A Charm....awesome Awesome.....
donstitan is offline   Reply With Quote
Old 08-24-2005, 11:13 PM   #21
mjs876
Send a message via AIM to mjs876
its 2 in the morining and i did the same exact thing......saved me a trip to the dealer tomorrow....thanx for the post
mjs876 is offline   Reply With Quote
Old 09-06-2005, 05:51 PM   #22
StriKing_Cobra
StriKing_Cobra's Avatar
Man i've done it about 10 times now and still no luck. Is there anything that possibly can be triggering this to come on?
2005 Titan SE Smoke Metallic
AVS Bug Gaurd
Fog Lamps w/Parking light tweak
Volant Gen3 CAI
Exhaust Custom Flowmaster 50 series SUV Performance exhaust.Click here to listen.
Grill- Mr. Grille
Headunit- Kept stock and added Audiocontrol LC6 a must for stock headunits!
Power-
Audiobahn 1 Farad Capacitor
Fronts-
JL Audio XR650CSi's 6.5 components
Total Mobile Audio 3202 Amp www.totalmobileaudio.com
Rears-
Diamond D361's www.diamondaudio.com
Soundstream Reference 200 Amp
Sub-
Single 12" Blaupunkt Overdrive
Soundstream Reference 500s Amp
StriKing_Cobra is offline   Reply With Quote
Old 09-08-2005, 05:27 AM   #23
usulsuspct
Awesome worked great for me!
I had to disconnect the battery to install my satelite radio, took a few tries but eventually I got it.
'05 Titan KC SE 4x4 - Canteen - BOD 3/05 | K&N CAI
usulsuspct is offline   Reply With Quote
Old 09-20-2005, 06:02 AM   #24
grunkster
Well I can't get it to work guys...i'll try the 5sec. of flashing light while in the ON position, and then 5sec. OFF 3 times as someone suggested to do differently...these things must be FUSSY!!
grunkster is offline   Reply With Quote
Old 02-02-2006, 06:48 PM   #25
cuba65
cuba65's Avatar
Re: Dash Air Bag Sensor Reset
This forum is awesome! Had a DVD player installed today, then the air bag light began to flash. Was dreading a trip to the dealer, but this fix worked like a charm. Thanks again!
cuba65 is offline   Reply With Quote
Old 12-02-2006, 07:58 PM   #26
Sir eel Green
I have already been to the dealer about this light. I just bought the truck used, and assumed there was a problem with the airbag. There may be. The dealer hooked it to the computer and told me it was a passenger side seatbelt tensioner, lifetime warranty on seatbelts, no charge. A second Nissan dealership closer to home said 99% of this trouble code instances are false readings from a wiring harness problem. It flashes one long, one short, then 5 shorts. Im going out to try the reset right now, then I'm going to the dealer next week for a seat belt tensioner....
Sir eel Green is offline   Reply With Quote
Old 12-02-2006, 08:13 PM   #27
Sir eel Green
Didnt work. Maybe I actually have a problem? Now the light just flashes, not in a long, short, five short sequence, but flash flash flash.....
So it did something. Then light comes on with the ignition, then after a delay it blinks off then on again. Do I turn the key off during the first blink off, or after the first blink on? Or does it matter...Does this reset only apply to trucks with no actual sensor issue, that were triggered by accident?
Old 12-08-2006, 08:25 AM   #28
mnmsmith
mnmsmith's Avatar
Awesome! I thought I screwed something up when I gutted the truck for stereo install. Went back through all the wiring 2 days ago, no problems that I could see. Dreading taking it to the dealer. I'll try this after work tonight!
Later that evening....
Worked like a champ! Thanks a lot!
'05 SE 4x4 Crew Cab - Radiant Silver
Radflo 2.0 Coilovers :: Rear Bilstein Shocks :: Zoomer's Cat-Back Exhaust :: Active Tuning Ground Kit :: Line-X Bedliner :: N-Fab Nerf Bars :: Grillcraft MX Grill :: 17x8 Enkei's :: Nitto Terra Grappler 295/70 17's :: Alpine HU :: Focal Component Speakers :: JL Audio 10W3's :: JL Audio Amps
mnmsmith is offline   Reply With Quote
Old 02-06-2007, 08:01 AM   #29
steve lund
i had the same problem after dealer serviced a seat squeak both airbag lights went off (supplemental and passenger airbag off)..dealer fixes both.. then a new radio goes in and supplemental air bag goes off. I bring it back to dealer and they say i need a part ..i also notice both before and after the new radio goes in that there is a buzzing sound in the radio ..it happens intermittenly ..can this be a short? Somehow the light reset itself while waiting to be fixed and i have yet to hear the buzzing sound again?????????
steve lund is offline   Reply With Quote
Old 02-14-2007, 03:22 PM   #30
John S
John S's Avatar
I just had satellite radio installed, and my airbag light was flashing. Did the 3 sets of waiting for the airbag light to turn off with the ignition turned + 5 second breaks, and the light no longer flashes. At least the annoying light is gone... however, now the orange passenger airbag light in the center console is no longer lit even when nobody is sitting there. Suggestions? Does this mean that the passenger airbag will go off in the event of an accident even if nobody is sitting there?
2005 S/C Elise
2006 Titan SE 4x4 Tow vehicle
2003 350Z Trackcar - RIP Buttonwillow
John S is offline   Reply With Quote
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
