Old 02-14-2007, 05:46 PM   #31 (permalink)
baseballfanz's Avatar
Re: Dash Air Bag Sensor Reset
Originally Posted by John S
Suggestions? Does this mean that the passenger airbag will go off in the event of an accident even if nobody is sitting there?
I believed that's how the 06 and newer work. On my 05 when no one is sitting in the passenger seat or if someone under the size limit sit there, light is on with an X telling me there's no airbag. If someone sit in it with the right size/weight requirement the light shut off. I believe with the 06 and newer the airbag is always "hot" until someone under the weight limit sit in it, than it shut the airbag off.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 02-15-2007, 03:33 PM   #32 (permalink)
John S's Avatar
Mine was always showing before when nobody was in the passenger seat...
2005 S/C Elise
2006 Titan SE 4x4 Tow vehicle
2003 350Z Trackcar - RIP Buttonwillow
John S is offline   Reply With Quote
Old 02-15-2007, 03:41 PM   #33 (permalink)
gadget74's Avatar
Mine is always off unless i have weight b/w 0 and i think 60 pounds in the seat. I think yours is working properly now.
Confucious say - Crowded elevator smell different to midget.
GoGoWhoreŠ
Helo Black Maxx 17's, BF Goodrich AT's, Jensen 7" indash DVD, 8" flip down monitor., 10" sub., Airbox Mod w/K&N Airfilter, NCD 2" Level Kit, Painted black rear bumper, Black Powder Coated Perforated Alum Grill, Magnaflow, Memphis door speakers, 2 degree timing advance!
gadget74 is offline   Reply With Quote
Old 02-15-2007, 06:45 PM   #34 (permalink)
Thumbs up Re: Dash Air Bag Sensor Reset
So I threw my airbag light when taking out my drivers seat to install a system. Turned on the ignition and tripped the code. Was at the dealer for a foggy headlight and they said they were going to charge me over $100 to clear the code. I declined that offer real quick. I'm going to check this fix out tonight.
05 CC LE Red Brawn
Nissan Bug/rock guard
SilverStar Low Beams
Gibson Side Swept Exhaust
Volant V3 CAI
PRG Mini Lift
18x9 MotoMetal wheels w/285/65/18 BFG AT's
Cobalt is offline   Reply With Quote
Old 02-16-2007, 04:02 PM   #35 (permalink)
John S's Avatar
That's what the dealer told me as well... I'm glad I came across this thread, which took only a minute to do and worked like a charm.
2005 S/C Elise
Old 02-18-2007, 11:57 AM   #36 (permalink)
John S's Avatar
Hmmm... now my fuel light isn't working when I get below that certain threshold...
2005 S/C Elise
Old 02-21-2007, 08:15 AM   #37 (permalink)
tholmes's Avatar
Took a couple of tries. Mine was a fast blink that slowed down when I tried off to on and wait for the first flash. Then it became a slow blink that finally shut off with a 4 off to on to off with a five second pause between cycles. Maybe that will help someone.
If it's a penny for your thoughts, and you give me your two cents, what happens to the other penny? Taxes, the Democrats tax everything!
Robert Holmes
2005 Titan LE Crew Cab 4x4 ***Gone, but not forgotten. Take your trailer hitch off when not towing, or else an impact could buckle your frame and warp your bed, causing the insurance company to total your truck ***
tholmes is offline   Reply With Quote
Old 03-09-2007, 12:05 AM   #38 (permalink)
eduardomi's Avatar
Hi guys, I cannot describe how frustated I feel... I've been trying the "original" method and its variations for 1 hour or more with no luck. I tried the
OFF - ON(1 blink) - OFF(5secs) - 3x ------- no luck
OFF - ON(5 secs) - OFF(5secs) - 3x ------- no luck
4x, 5x and 10x no luck!!!!
I have a 2006 CC. And all started earlier today when I was changing the head unit (DASH OFF) and turned the ignition on to roll the windows...I know that screwed the airbag thing but now I cant fix it.
When I go from OFF to ON all the lights in the panel come ON and ALSO the little light with a X in the middle of the panel.
I bought the car yesterday please dont tell me I have to go back!!!
?What am I doing wrong?
Please HELP!!!!
S O S
wORRY eD.
eduardomi is offline   Reply With Quote
Old 03-09-2007, 08:22 AM   #39 (permalink)
Worked like a champ for me. Now im not mad at it anymore.
NoFriends714 is offline   Reply With Quote
Old 03-09-2007, 10:33 AM   #40 (permalink)
eduardomi's Avatar
S. O. S.
Old 03-10-2007, 09:54 PM   #41 (permalink)
MrTitan2005's Avatar
Talking Re: Dash Air Bag Sensor Reset
good looking out work perfect the 1st time and it has not come back on !
MrTitan2005 is offline   Reply With Quote
Old 10-02-2007, 10:51 PM   #42 (permalink)
Im glad i came across this too. took off my front radio bezel to install my sat radio and unpluged my passenger airbag light when ign was on and the light came on. took it the dealership and they said did u install any aftermaket audio. i said yes then they were like well its goin to $96 to clear the code, F#$% that.. Forums saved me again...
yamaguy88 is offline   Reply With Quote
Old 10-14-2007, 04:12 AM   #43 (permalink)
Thanks, worked fine for me after the first time. I installed a new aftermarket stereo and thought I damaged a cable but it is probably because the passenger airbag warninglight was disconnected.
Niels.Spieard is offline   Reply With Quote
Old 02-19-2008, 10:16 PM   #44 (permalink)
MikeB's Avatar
I just had to do this and it took several dozen tries to get it right. I think I came up with a procedure that will help alot of you with bad timing like myself.
First, you know how when you leave your key in the ignition in the off position with the door open your truck beeps at you? "beep beep beep beep ----beep beep beep beep----beep beep beep beep" Well, you can use that as a timer.
Open the drivers side door and put the key in the ignition.
Turn it to the On position and watch the air bag light. It stays on for several seconds and starts blinking. Watch it closely. As soon as it blinks ON for the first time, IMMEDIATELY shut off the ignition.
Wait for 5 "beep beep beep beeps" and turn the ignition back on.
Do the above 2 more times.
On thr last time watch the airbag light. It should start blinking slowly. At this point let it blink a couple times and turn off the ignition for 30 secons or so.
You should be fine now.
2006 CC Titan SE 2WD BT. Injen Powerflow, TB Coolant bypass, JBA Evol Exhaust with Maglaflow 24" muffler, Bully Dog Power Pup, Leveling kit, $22 helper springs.
MikeB is offline   Reply With Quote
Old 03-11-2008, 04:32 PM   #45 (permalink)
Rolex's Avatar
I removed the HU today and disconnected the passenger airbag light which tripped the blinking airbag light on the dash. I followed this procedure to the letter and it worked. I actually ended up doing the procedure 4 times instead of 3, but it worked all the same.
2008 Pro 4X - this forum saved me $100.
Expecting the world to treat you fairly because you are good is like expecting the bull not to charge because you are a vegetarian.
Rolex is offline   Reply With Quote
