**UPDATED** E-Lock in 2WD, 4HI and 4LO - Page 9 - Nissan Titan Forum
Old 03-12-2012, 07:14 AM   #121 (permalink)
phatplat's Avatar
iTrader Score: 0 reviews
Re: **UPDATED** E-Lock in 2WD, 4HI and 4LO
How do I know if I can do this? I have an 06 4x4, no vdc, no abls that i've encountered yet either. 1wd, or 4wd. thats it.
2006 SEKC4X4
phatplat is offline   Reply With Quote
Advertisement
Old 03-12-2012, 07:22 AM   #122 (permalink)
08pro4x2486's Avatar
iTrader Score: 2 reviews
If yours has an electronic locking rear diff you can do it.
2008 Pro4x KC Smoke Best 1/4 mile 14.4739@93.61mph 2.0581 60ft in 2499DA. 354.8rwhp 418.1lb/ft on 87 octane tune (hub dyno)
Thrust: Airaid MXP 4" Intake, FT90mmFTW, Stillen (CSF) radiator, Stillen LT headers, Berk B-pipes, Nismo Catback, E-lock mod, Burn Out Mod, and Uprev.
Suspension:PRG UCA's, Ext. length SAWs, Swaybar removed, PRG camber bolt kit, Deaver C30, Radflo 2.0 remote reservoirs, PRG shackles, and N-Fab Traction Bars. Radflo air bumps waiting to be installed.
Exterior: Lots of DIY stuff, custom prerunner bumper w/4 Hella 500 HID's, 35X12.50 General Grabber AT2's, XD Diesel's powder coated flat black, VIAIR on board air compressor w/tank.
RIP TINA
08pro4x2486 is offline   Reply With Quote
Old 03-12-2012, 08:11 AM   #123 (permalink)
phatplat's Avatar
Good call. Is there a button or something that tells me that. Do I need to crawl under the truck to find out? I did not buy it new, I dont have the window sticker.
2006 SEKC4X4
Old 03-12-2012, 08:14 AM   #124 (permalink)
Irish125's Avatar
iTrader Score: 1 reviews
Originally Posted by nismojunky View Post
Okay just double checking I can run a wire from terminal 4 to 8 for the ground and same with terminal 3 to switch
Terminal 4 and 8 both need to go to the ground from the DLCU. If you just run leads from both terminals to a wire tap onto the ground from the DLCU you should be good. Terminal 3 and the switch both need to tie into the blue wire from the DLCU. So again if you just tie them both together and tap into the blue wire it should work. Hope that helps.
LousyLuckWhore™
2010 Pro-4X CC Galaxy Black
E-Lock MOD
Irish125 is offline   Reply With Quote
Old 03-12-2012, 09:47 AM   #125 (permalink)
Below the radio and HVAC controls there should be switches for tow mode, E-lock, VDC, etc. if you don't see an E-lock button you don't have one. It would look like a stick figure of the trucks drivetrain with an "X" on the rear diff and it will say "Lock" underneath it.
RIP TINA
The Following User Says Thank You to 08pro4x2486 For This Useful Post:
phatplat (03-12-2012)
Old 03-12-2012, 09:48 AM   #126 (permalink)
phatplat's Avatar
Ahh. Balls. I dont have it. Would that be something that I can add from a vehicle that does have it?
2006 SEKC4X4
Old 03-12-2012, 09:53 AM   #127 (permalink)
You could, but the easier route would be to get a Detroit Trutrac.
RIP TINA
Old 03-12-2012, 11:12 AM   #128 (permalink)
phatplat's Avatar
Yes, I have been looking at those. Just not sure about the 600 or so. Is it worth it, so on. I will sit on it a bit more. Thanks for your help man.
2006 SEKC4X4
Old 03-12-2012, 03:34 PM   #129 (permalink)
Send a message via MSN to nismojunky
thanks thats what i thought ill hook everything back up tonight and go for a spin see if i can get the light to come on
2006 Titan CC Offroad
Factory Options - Granite, E-locker, Big Tow, RF, Utili-Track
Performance - JBA Cat back, S&B CAI , Rear Axle Vent, TrueTrac, DIY Ground Kit, UpRev, Power Stop Brake Kit, 2* , WOT Removed, TB Bypass, Vibrant UQ res, Burnout Modd, OBX LT Headers, Cajin Catted 4x4 B-pipes, CST alu rad
Suspension - Driveshaft Spacer, PRG Cam Bolts, PRG SBEL's, PRG Shackles, C-30 Leafs, PRG OFFROAD Traction Bars, Radflows on 4", PRG UCA's, 1" Blocks Rear, Air lift Airbags
Exterior - 4X Hella 500 Black Magic Driving lights, 6k HI/Low/Fogs, Backup lights, Back Rack, 35/12.5/R17 Nitto Trail Grapplers
nismojunky is offline   Reply With Quote
Old 03-12-2012, 06:02 PM   #130 (permalink)
okay went and tried it again still nothing. i tried hitting the factory switch to see what would happen the diff lock flashes twice then disappears and stay off Im I on a wrong wire possibly?
Old 03-14-2012, 08:34 AM   #131 (permalink)
Irish125's Avatar
Could be a wrong wire. I never had the light flash and go off like that. Try to retrace all the wires to be sure you didn't get one crossed up somewhere. Usually if you hit the factory switch not in 4lo it will continue blinking.
LousyLuckWhore™
E-Lock MOD
Old 03-16-2012, 08:12 PM   #132 (permalink)
tried at the back of the truck same results maybe i have a faulty replay?
Old 03-16-2012, 11:18 PM   #133 (permalink)
DRTYAZN's Avatar
iTrader Score: 12 reviews
Either that or you might have shorted a 4X4 safety sensor, it'll make the 4X signal flash intermittently while trying to engage it as well... You'll need to perform the ECU Reset, then try activating the locker again afterwards... but I've never seen the Diff lock light flashing, so you might even have a faulty locker controller???
DrtyAzn
Slightly Modified 4X4 '06 Titan CC
DRTYAZN is offline   Reply With Quote
Old 03-20-2012, 04:55 PM   #134 (permalink)
Don't worry about it haha it's truetrac time rear end just went out today haha
The Following User Says Thank You to nismojunky For This Useful Post:
DRTYAZN (03-21-2012)
Old 03-21-2012, 09:09 PM   #135 (permalink)
DRTYAZN's Avatar
That fixes the problem...
DrtyAzn
Advertisement
E-Lock locked in 2WD, 4HI & 4LO Austin Titan Engine, Transmission & Drivetrain 197 01-14-2012 11:38 AM
swithching from 4hi to 2wd hoyt57 Titan Engine, Transmission & Drivetrain 4 02-06-2010 11:57 AM
Pro4X e diff lock - 4H or 4Lo only? crenca Titan Engine, Transmission & Drivetrain 13 11-26-2009 09:27 PM
ABS light on in 4lo with Diff lock AF-Medic Titan Engine, Transmission & Drivetrain 7 01-06-2009 09:51 PM
I just had to try the 4LO & E-LOCK HudsonValleyTitan Titan General Discussion 4 02-11-2007 07:09 PM
SEO by vBSEO 3.3.2
