Has anyone got the automatic headlights to work on an SE yet?
SE King Cab 4x4 - Born on 1/04
Big Tow - Off Road / No E-Locker
Rockford Fosgate with Captains Seats
Utility Bed - Lower Tray - Tool Box Weatherflectors
Lund Interceptor Bug Shield
Westin Bull Bar
Westin Driving Lights
AFE Stage II CAI
Bilstein 5100 adjustable front shocks - set at 1" lift
Icon Rear Shocks
SkyFi 2 XM radio
Cell phone install kit w/ SmoothTalker 3 watt booster - almost always have a good signal now.
I'm interested to know where you guys are ordering your fog lights from. I haven't looked very hard yet, but if there are plug and play fog lights that are made for this truck, I'd order them in a heartbeat.
I'm working on this one! It might be a case where Nissan has taped the connector feed way down to the main harness where you can't see it from above!! Nissan likes to do that alot! I will keep you posted.
-Jamie
I just got mine as an-add on through the dealer when I got my SE; they are the same as the ones used with the off-road and LE packages. If only that auto feature would work... miss having that.
2004 Titan 4x2 SE Crew Cab, White
Rockford Fosgate w/ bench
Utility Bed, Big Tow, fog lights
^ ^ No sir, off road package's are availabel for 2wd models as well. Its kind of like the popular package or big tow package, just another package that adds different parts for more money...
No problem, forums are good for learning new things...
-Jamie
Jamie,
Any luck?
Really hope this is possible, I want to do it bad!!!
Rob
'08 Pro-4X LWB Galaxy Black 4WD
Tow, Utility Bed, Rockford Fosgate
Captains Chairs,
PRG mini lift
Zoomers Cat-back exhaust
Hatchie Bottom Max-4 camo seat covers
Nissan Bug Guard
Chrome Nissan Running Boards
Husky Liners
Nismo CAI
Active Tuning Grounding Kit
Eco-3
5000K HID Low Beams
and
'05 SE KC Galaxy Black
Big Tow,Off-Road, Utility Bed
Rockford Fosgate
Captains Chairs
Nissan Bug Deflector
Husky Liners
PRG Mini Lift, Chrome Tailgate Trim, Billet Grille
Window Tint
Leer 100XQ Shell
Extend-A-Fender Flares w/Factory Mud Flaps
Hatchie Bottom Custom Fit Max-4 Camo Seat Covers
Zoomers Cat-Back Exhaust
NISMO CAI
5000K HID Low Beams/ Silverstar High Beams
Active Tuning Ground Kit
I am another SE buyer who cant believe the autolight feature was not included on such a badass truck. i LOVE it on my bmw and cant live without it. I may be up to he mod if we want to hold an open discussion of what we know so far.
What we know so far is in this thread. Where we are at is this: The wiring harness does not appear to have the necessary wiring run up to where the sensor mounts at on the dash. Jamie was going to try and trace this down but never posted any results. (see Titanparts1 post in this thread)
So, if the wiring for this exists then great we can simply wire it up, program and go. If the wiring does not exist then it would have to be added which would be a big job indeed. Not a task I would take on.
So Jamie....what did you find out???
Steve - "A Rumor Is Nothing More Than An Unconfirmed Fact"
If it's any help, the sensor connects to pins 18 and 58 on the BCM. Pin 18 is the sensor ground, and pin 58 is the sensor signal. The factory install sensor wire connects into the Super Multiple Junction. If you are adding the sensor you could wire it directly to the proper pins on the BCM. Then you will have to install the light stalk with the auto light feature.
However, the BCM must be programmed for the auto lights.
See attachment:
See attachment:
That's true, those wires could be checked to see if they are present at the BCM and if not they could be run. Do you know if the wiring exists that would run from the light stalk to the BCM? Also, FYI....Anyone who installed the factory fog lamp kit has the light stalk with the auto light position because that's the way the stalk comes.
It's been a long time since I have given any thought to this whole notion of adding the auto light function but I believe that the light stalk wiring to the BCM was confusing me so I gave up. I'm at work now so I don't have access to the wiring diagrams.
I think the wiring from the light stalk is present. This is not a standard switch operation. All the switching on the stalk is done with low level voltages and current. These signals are sent to the BCM which controls everything. The switches in the light stalk are arranged in a matrix. This requires fewer wires, and each wire serves several purposes. Since all the matrix wires have to run to the BCM there should be no problem in replacing the light stalk with one that has the Auto switch. (Same thing when adding fog lights - all you have to do is replace the stalk)
See attachment for the matrix diagram.
