All, here's a picture I labeled some time ago on how to check your ATF level. There are a few VERY important things to remember before you do this:
1. The transmission should be up to normal operating temperature.
2. Use only a clean piece of paper to wipe the dipstick after you remove it.
3. Be EXTRA careful when doing this because the engine has to be running when you check the level.
4. Use ONLY Matic-J Nissan Approved ATF if you need to add some.
