Old 01-26-2005, 07:05 PM   #1 (permalink)
smellin13's Avatar
Question Difference in TOW abilities
I have an XE Crew Cab 4x4 off road, however the XE is only rated to pull 6500lbs as apposed to the LE/SE which is rated at or about 9500lbs. With the same exact engine that all Titans have, and the rancho shocks (OR package), why am I only limited to 6500lbs? I am finally getting my horses this spring and can't find any differences that should keep me from towing at least 8000lbs. I have tow mode and everything. Are the differentials different, what upgrades do I need, is the XE underrated? I have heard so many different answers that I really would like to know the truth, even 3 Nissan dealerships could not answer my question. The big tow package seems to add the class IV hitch and electric, I can do that, but I want to feel confident I am not missing something that will kill my truck. Please help. Thanks,
Shane
smellin13 is offline   Reply With Quote
Old 01-26-2005, 07:07 PM   #2 (permalink)
rarjar's Avatar
I believe unless you have the big tow package the towing, regardless of XE, SE or LE, is around the 6500 lb range. I regularly pull 8500lbs +/- so I got the big tow.
2004 Titan 4x4 Pearl White LE King Cab
Tekonsha Voyager Trailer Brake Controller
OEM Bed Divider
Superior leaf spring helpers
Lund X-terminator bug shield
Graphite/Titanium leather seats
Born-on date 6/10/04
Purchased 6/19/04
"We're all here because we're not all there!"
rarjar is offline   Reply With Quote
Old 01-26-2005, 07:12 PM   #3 (permalink)
smellin13's Avatar
Right, but what does the Big Tow offer that boosts its rating?
Old 01-26-2005, 07:21 PM   #4 (permalink)
rjspitz's Avatar
It's about the money... You can only tow 9500lbs if you give us $8000 more for leather, power windows, floor shifter, captain's chairs...
Directly off Nissan's site:
Big Tow Package (SE and LE Only)
• Class IV receiver hitch
• Additional 7-pin wiring harness plug
• Trailer brake controller pre-wiring under instrument panel
• Heavy-duty battery (710 CCA)
• Lower final gear ratio (3.36:1); similar to 4.10:1 on a 4-speed automatic
• Extendable tow mirrors
• Transmission temperature gauge
• Increased tow capacity
SE: Requires Trac Package (4x2 only). In addition, SE Rockford Fosgate Package or SE Popular Package is required.
Old 01-26-2005, 07:24 PM   #5 (permalink)
Bill_n's Avatar
The hitch ....
Bill_n is offline   Reply With Quote
Old 01-26-2005, 07:29 PM   #6 (permalink)
rjspitz's Avatar
Most people buy vehicles ready-to-go. Most don't like to deal with having to buy a couple more parts for their car right after they just threw down $$ for the new car itself. It's all about marketing.
Just get any aftermarket Class IV hitch, tranny cooler, and brake controller.
Old 01-26-2005, 11:21 PM   #7 (permalink)
BigRedTitan's Avatar
The lower final gear ratio on the Big Tow is what makes the difference.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 01-27-2005, 08:54 AM   #8 (permalink)
QWIKWHIP's Avatar
That's correct. That is what makes the biggest difference. My SE with out big tow is rated for 7500 pounds. The only difference between the XE and nonbigtow SE/LE's that I could see may be the tires. The XE's 17" steelies with smaller tires may have a lesser capacity?? Just a thought.
Old 01-27-2005, 09:35 AM   #9 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
I believe the tires going up on 17" for O/R or 18" are rated higher for more weight. This will get corrected if needed by others but I'm fairly certain. Gear ratio, tranny temp gauge are the 2 biggest factors right away other than tires...
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 01-27-2005, 08:35 PM   #10 (permalink)
smellin13's Avatar
Thanks all
Old 01-27-2005, 09:11 PM   #11 (permalink)
Isn't the final gear on both the OR and BT the same
3.36:1? If Smellin13 has the OR and is only rated for
6500, then it's got to be more than the lower final gear
ratio that makes the difference
Nr1 Qualifier
2004 LE KC 4x4
Nr1 Qualifier is offline   Reply With Quote
Old 01-28-2005, 07:43 AM   #12 (permalink)
QWIKWHIP's Avatar
Maybe just marketing??
Old 01-28-2005, 10:47 AM   #13 (permalink)
uhhhhhhhhhhhhhhhhhhhh
Xelvic is offline   Reply With Quote
Old 01-28-2005, 10:59 AM   #14 (permalink)
OR and Big Tow have the same final gear ratio and tran cooler. Just don't get tran temp gage and VDC w/o Big Tow. At least I think this is true for the 04's.
Old 01-28-2005, 01:59 PM   #15 (permalink)
Send a message via AIM to Timba24
I thought the big tow also came with a upgraded radiator
Timba24 is offline   Reply With Quote
