Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan FAQ & Howto Area
User Name
Password
How do you Remove front bumper? - being discussed at Nissan Titan Forums in the Titan FAQ & Howto Area section.
Old 04-09-2005, 05:59 AM   #1
dalt1
dalt1's Avatar
I have a small dent in my front bumper chrome section and want to take it off to knock it back out. The dent was compliments of a parking lot bump and run. Luckily not to bad. Does anyone have the removal process?
05 LE CC 4x4, Big Tow, XM, Tinted windows, Chrome 18" QX 56 wheels,Bridgestone Revo AT tires, Stainless Chromed Westin Bull Bar, 4PC APS alluminum billet grill, Stainless exhaust tip, PRG leveling kit, PRG modified Bilstein rear shocks, Air Lift 1000 rear suspension leveling kit with Load Controler II inflation system, Lund Genesis Trifold Tonneau, Stampede Bug Shield, EGR in channel window vent visors,Power Tailgate Mod.
dalt1 is offline   Reply With Quote
Old 04-09-2005, 07:06 AM   #2
scr38
scr38's Avatar
These drawings may help:
Click image for larger version
ID:	9920  Click image for larger version
Old 04-10-2005, 05:43 AM   #3
dalt1
dalt1's Avatar
Thanks, I got ot off and back on already. Got the dent out and put my new Westin Bull Bar on.
Old 04-13-2005, 10:02 PM   #4
VShortt
VShortt's Avatar
I was going to suggest a sledgehammer. Your idea seems much more inviting.
New List of Mods Coming soon
Old 04-28-2005, 10:38 AM   #5
Justin311
How long did it take? Any tricky parts?
Justin311 is offline   Reply With Quote
Old 04-29-2005, 05:02 AM   #6
jhromy
Banned
jhromy's Avatar
man that tool can fix anything
jhromy is offline   Reply With Quote
Old 08-20-2005, 03:41 PM   #7
RB's Titan
RB's Titan's Avatar
Bumper Replacement Instructions LE
Time to set aside for project 2-3 hours (one man)
Tools needed:
- 12mm socket 3/8 drive is fine
- Short handle flathead screwdriver
- Long flathead screwdriver
- Pliers
- Standard Phillips head screwdriver
Removal: See pics as they are named for their order of removal.
Step 1: (pics Step 1)
Remove plastic body pieces two. Use flat head screwdriver to disengage clips and lift out of place.
Step 2: (pics Step 2)
Remove Grill by using flathead screwdriver to carefully twist 45 degrees the square heads of plastic clips (Step 2 pic) . There are about 8 I think in total.
Step 3: (pics Step 3A & B)
Once clips turned use the screwdriver to aide in the disengaging of top two push clips left & Right side. There are four clips total. You can see their spacing in Step3B pic after grill is removed. With grill removed your truck looks like this (grill gone pic)
Step 4 & 5: (pic Step 4-5)
Disconnect fog lights if needed and use 12mm socket to remove left & right side support nuts.
Step 6: (pics Step 6)
Remove 2 lower bumper bolts with 12mm socket wrench.
Step 7: (pics step 7)
Remove 4 top bumper bolts.
Step 8: (bumper grill removed)
Remove bumper buy lifting up over metal flap. See step 7 pic as the metal flat is to left of bolts. Pull straight away. Bumper only weights about 45lbs.
Step 9: (pics step 9A,B,C)
Remove the plastic body pieces by depressing clips and unscrewing Phillips head screws.
Installation: Reverse the procedure. However remove the side support braces before beginning bumper installation.
Hint: (pic Install last)
Remove complete support brace from frame using 12mm socket. Once bumper is in place and bolts are finger tight align side braces to the two bumper bolts. Placing the support brace into the bumper bolts first before sliding and bolting to the frame. This step will save you many minutes when trying to align your bumper bolt holes.
Good luck
ID:	15630  Click image for larger version
ID:	15631  Click image for larger version
ID:	15632  Click image for larger version
ID:	15633  Click image for larger version
Randy
IRC CREW CHIEF - International Racing Club VK56
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 08-20-2005, 03:43 PM   #8
RB's Titan
RB's Titan's Avatar
More Pics
MOre install pics...
ID:	15635  Click image for larger version
ID:	15636  Click image for larger version
ID:	15637  Click image for larger version
ID:	15638  Click image for larger version
Old 08-20-2005, 03:48 PM   #9
RB's Titan
RB's Titan's Avatar
Last of install pics
Here are the final pics for post above.
ID:	15640  Click image for larger version
ID:	15641  Click image for larger version
ID:	15642  Click image for larger version
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
