My Homelink button is always on even when car is off. I think this poses as a security risk into my garage. How do you power off the homelink so that when the key in ignition is in the off position so is the homelink?
Randy IRCCREW CHIEF - International Racing Club VK56
Sorry I don't have a fix for you, but ... With most door opener remotes being battery operated they are always on too.
Tom
05 Titan SE CC 4X4 | Deep Water | Big Tow
Pop Pkg | Utilitrack w/ extender & divider
Born on 2/05 Mine 4/05
A.R.E. LS II added 6/05 | Step Rails added 4/06
This is an interesting point. Having thousands of code combinations from a rolling code door opener is no good if all a theif has to do is break in your truck and press the button. To eliminate the problem with a non Homelink remote all a person had to do is carry the remote control inside the house at night.
Thanks to you, I now know to lock the garage door from the inside when I go on vacation and the Titan is left parked in the driveway.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Most thieves are stupid, although it could happen I doubt that many thieves would know which vehicle had home link or not. Even then they would have to know where the transmitter on the truck was located.
I'd be more afraid of getting struck by lightning.
2001 Polaris Sportsman 500.
I believe that what he is trying to point out is that if his truck gets broken in to, then a thief would then have easy access to his garage.
Right on the money VShort.
Originally Posted by rjspitz
You could re-wire it into the ignition. My Audi is wired this way. It's actually a pain in the a$$ to have to turn the key to open the garage door.
This would be the preferred method.
With remotes they can be hidden away but the homelink is in plain view and always in the "Same" place. I probably should not have mentioned this problem...now a "Smart Thief" can get in.
Well I've been digging for infromation and have found Manufacturer Information but no wiring details.
https://gullfoss2.fcc.gov/prod/oet/cf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout =500&calledFromFrame=N&application_id=475363&fcc_i d='NZLCTHL3'
I'll call Gentex and see if they can help me. thanks for all your thoughts.
Not sure if this will help any or if anyone is still looking at this thread, but I have ripped out a couple homelink modules from the visors of dodge and chrysler cars to mount on my sportbike, The one's I ripped out only run on 2 wires (pos & neg) but if I remember right, if you were to disconnect it from the constant power, you would lose the memory of the code you are trying to send. I am almost positive that is how the older versions worked, I have two different ones(rolling codes, and non)I would be happy to hook one back up to test this theory further if anyone is still interested
