Originally Posted by blueskys
STEP 1: Gain access to backside of bezel by firmly grabing top of dash sill and pull aft. The bezel is held in by clips and will seperate from the dash with minimal force. Once the bezel is about 2-3 inches from dash, reach behind plastic plug and push it out with your fingers. Place a butter knife under the lip of plug and force it full out of bezel.
Sorry to bring back and otherwise dead thread, but I discovered an alternate way to perform step one here that I've not seen mentioned elsewhere.
You can pop out the plug in question from underneath the driver side dash without pulling the bezel out/off.
Recline driver side seat all the way and get in - backwards (LOL) so you can access under the dash. Get a bright light and shine up towards where the plug is located. You'll see it up there and should have a straight shot at it with a long prodding device of some sort (I didn't have a screw driver long enough... so I used a really long file).
You'll need one of the two retaining tabs to be facing you so if you don't see one, you'll need to rotate the plug until you do (you would do this from the front of the dash... not behind). At any rate, take your long "stick" and gently push up on the retaining tab to disengage it. The plug will pop out slightly.
Then have your wife help you extract your contorted body from out under the dash and pull the plug the rest of the way out!
I don't know how quick it is to pull the dash bezel out... so this might take you a couple minutes longer (took me about 30 seconds once I located the plug)... but with this method you don't have to pull on anything that could potentially crack/break etc. And with my luck, that was bound to be exactly what happened! LOL
