Old 08-24-2009, 10:09 AM   #106 (permalink)
Re: Axle vent issue and solution
you should do it if your axle will ever get wet. In florida the rainy season creates some deep puddles around here plus I go off-road so I need to do the mod. As far as dunking a boat I doubt you'll be getting the axle underwater.... but better safe than sorry
mmtitan is online now   Reply With Quote
Old 08-24-2009, 02:31 PM   #107 (permalink)
gabriel c.'s Avatar
so whats the deal with the 1/4"fitting from ace? is it not the correct thread size?
third coast titans
gabriel c. is offline   Reply With Quote
Old 08-24-2009, 03:30 PM   #108 (permalink)
No, get the Toyota part.
Old 08-25-2009, 02:52 PM   #109 (permalink)
SATXTITAN's Avatar
Toyota part # 90404-51026 List $6.63.
<a href=http://img21.imageshack.us/i/cimg2780b.jpg/ target=_blank><img src=http://img21.imageshack.us/img21/4859/cimg2780b.th.jpg border=0 alt= /></a>
SATXTITAN is offline   Reply With Quote
Old 08-25-2009, 03:13 PM   #110 (permalink)
m1key's Avatar
I used the the same fiting that came with the axle easy
http://i612.photobucket.com/albums/tt203/m1key808/pics006-1.jpg
m1key is offline   Reply With Quote
Old 08-25-2009, 04:57 PM   #111 (permalink)
gabriel c.'s Avatar
did you just take off the cap? is there enough space for the clamp?
third coast titans
Old 08-25-2009, 05:00 PM   #112 (permalink)
m1key's Avatar
Yup
Old 08-26-2009, 11:50 AM   #113 (permalink)
Orderd my yota part. Was about 4 bucks. Install gettin done on friday
Old 09-09-2009, 09:43 AM   #114 (permalink)
SATXTITAN's Avatar
Anyone happen to know if this Toyota fitting will work on a 07 Nissan Xterra as well? I'm thinking about doing the same mod on my wife's Xterra. I would assume it would thread right in since its a Nissan as well, but we all know what sometimes happens when we assume things.
Old 09-09-2009, 10:39 AM   #115 (permalink)
krh2's Avatar
It worked on my wife's 05 Frontier.....
krh2 is offline   Reply With Quote
The Following User Says Thank You to krh2 For This Useful Post:
SATXTITAN (09-09-2009)
Old 09-09-2009, 02:54 PM   #116 (permalink)
What a great, simple mod. Buy eight feet of hose though. I kinda gave mine some slack at the axle for room to play, and then ran it through the frame. Then out the back of the frame and up to behind the tail light. With 7' of hose I didn't have enough left to curl it over the tailgate "relief spring" or whatever it's called so I just zip-tied it to the base of the tailgate spring thing.
So buy 8'
Old 09-11-2009, 03:05 PM   #117 (permalink)
Smoke05's Avatar
What kind of sealant is being used on the threads?
Smoke05 is offline   Reply With Quote
Old 09-11-2009, 04:18 PM   #118 (permalink)
I used Permatex High Temperature Thread Sealant (same as on diff drain & fill plugs).
http://www.permatex.com/documents/td...tive/59214.pdf
Old 09-11-2009, 05:32 PM   #119 (permalink)
layer1's Avatar
Was the stock valve redesigned on the 08+ axles and if so does is the MOD necessary?
Has any 08+ owners done this MOD?
1/4 Mile in 14.89sec | 90.43mph @ 5900pnds
AKA: ScotchWhore
layer1 is offline   Reply With Quote
Old 09-12-2009, 10:08 AM   #120 (permalink)
SATXTITAN's Avatar
I used teflon tape.
