Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan FAQ & Howto Area
User Name
Password
anybody done an IAT mod? - being discussed at Nissan Titan Forums in the Titan FAQ & Howto Area section.
Old 02-26-2008, 07:59 PM   #16
vipzach
vipzach's Avatar
Re: anybody done an IAT mod?
This makes as much sense as buying one of those fans and putting it in your intake tube!!!! 20+ HP, for $19.95!!!
Come on guys, if it seems to good to be true...................
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
vipzach is offline   Reply With Quote
Old 02-26-2008, 08:32 PM   #17
TitanLou
TitanLou's Avatar
Are you talking about the turbonator. I was thinking about getting one to put inside my S&B intake tube.
j/k
2005 CC Smoke,BT,RF
S&B CAI
Magnaflow Exhaust
LEER Top
Stampede Bugshield
Stampede Ventshades
coming soon
Roadmaster Active Suspension
TitanLou is offline   Reply With Quote
Old 02-26-2008, 09:58 PM   #18
Sftail1990
Sftail1990's Avatar
Originally Posted by pedalhappy1053
Just buy NOS if you want performance.....thats what Ima do when I get more money
Anybody that does these resistor mods trying to make horses that won't exist for the IAT, I don't even want to be in the same state if they try to play with nitrous down the road. Not that the IAT will do anything with nitrous but I just don't wanna be around when they think "just a lil more juice will really make it go" mentality. Will surely be an exhibition of convincing the slugs to change holes.
2006 Titan SE CC w/ Big Tow
Chrome Package w/chrome 18" 6-Spoke
S&B Intake w/AirRaid TBS
ReTrax Bed Cover
Axle Vent Mod
Sftail1990 is offline   Reply With Quote
Old 03-05-2008, 04:09 AM   #19
mb1134
Hell just get a potentiometer and you could adjust it yourself. Although i wouldnt reccomend this mod at all. Im not sure but i would guess that its not the best way to get the same results.
mb1134 is offline   Reply With Quote
Old 03-05-2008, 07:44 PM   #20
BrianCMM
BrianCMM's Avatar
This mod can work, but not on a Titan. This was a quick, cheap mod that was used on DSM's (Eagle Talon's, Mitsu Eclipse's) as opposed to buying an expensive AFC (Air Fuel Computer). The mod only works if you really do introduce more air into the engine than the MAF has counted. That way the extra gas that's injected, due to the IAT resistor, will keep the engine in the proper stoichiometric range.
I had this mod for a while on my Talon. It's a turbo motor and is very easy to add more intake air. But the ECU would cut the fuel off after what it deamed was too much intake air passing through the MAF. Thankfully, it was also very easy to modify the MAF to allow more air to bypass the MAF sensor, thus eliminating the dreaded fuel cut, but also creating a lean mixture. To correct this lean mixture, an IAT resistor could be added to allow more fuel to be added and this would then richen the mixture. But it is still a guessing game, so I used a very sensitive Air/Fuel Ratio gauge to measure the exhaust gases and tune for the desired stoichiometric ratio.
But adding a IAT resistor (or these so called "chips") to an engine, without also adding more air, will do nothing but make your truck run worse...it will run too rich, which will actually waste fuel.
BrianCMM is offline   Reply With Quote
Old 03-06-2008, 05:20 AM   #21
BK19702
BK19702's Avatar
Amen to that.
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 03-06-2008, 04:09 PM   #22
mikesrex
I wouldn't try this. If you guys are serious about making the truck fast, then do it the legit way. Build the motor and get a good EMS. Or get a good fuel system, turbo and EMS.
mikesrex is offline   Reply With Quote
Old 03-20-2008, 07:22 PM   #23
hdlstns
hdlstns's Avatar
Not to mention, if you were to try to install this resistor, you would have to splice it into the harness coming from the MAF sensor...not a real easy thing to do like they promise on those ebay auctions. Maybe on SOME vehicles it is plug and play, but not a Titan!
Love my new (to me) '04 Sedona Titan SE CC 4x4OR
Truxedo, TrailFx visors and bug shield, Husky liners, more soon!
hdlstns is offline   Reply With Quote
Old 04-21-2008, 10:23 PM   #24
enterprisevending
So What The Hell Is The Answer??? Which Two Wires Does The Guy Tap Into? Either Shut Up Or Answer Him.
enterprisevending is offline   Reply With Quote
Old 04-22-2008, 05:12 AM   #25
BrianCMM
BrianCMM's Avatar
Yeah, OK..."Shut Up Or Answer Him." That's a useful post! Why not take your own advice!!
Sorry that we tried to actually help someone by educating them as to what an IAT resistor mod is and why it's useless on a Titan.
Old 04-22-2008, 08:05 AM   #26
Clancy
Clancy's Avatar
He should find one of the wires coming out of his a$$, and the other in his wallet. Connect those two. Guaranteed to make 40 hp.
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Old 04-23-2008, 09:02 PM   #27
Trigger
I've just join and this makes me sad, that a guy would be flamed and cursed for wanting an answer to an asked question. I would expect it from a user with less than 50 posts but not from a user with over 850. You all have voice your (educated and not) OPINIONS and NO ONE has answered the question. We live and learn, and if he wants to do this after reading this its his choice. MAYBE he will discover something about the ECM, IAT, MAF (backdoor, flaw, bug, etc..) Like there has never been an exploitable bug in software or an electronic device, YEA and my name is Bill Gates. I'm done now you can flame me or just answer the mans question.
P.S. look here: /titan-performance-modifications/67478-fuel-mod-new-chip.html?highlight=resistor+ecm
Originally Posted by INTRCPTR187
I have one>>>>>When I got my baby before I was a member of this vast knowledge base that is titan talk I bought one of these chips. I even still have it installed.....I have yet to dyno my truck but accordingto my belltronics vfx2 it does make a slight difference I have taken it off left the ecu to reset for 12 hours and tested and repeated the same only reinstalling it....Maybe its just my overactive imagination but I can feel a slight difference in power.......Who nows maybe Im crazy but for 5 bucks im not gonna knock it.....As far as gas mileage I dont know I have a lead foot.
Trigger is offline   Reply With Quote
Old 04-23-2008, 09:30 PM   #28
Nissan Mike
Nissan Mike's Avatar
Hey if someone wants to try this I say let them. We can sit all day and give our BS on why it should or should not work. Alot of great things have been accomplished by going against the flow and trying something on your own.
They all laughed when Gale Banks wanted to set the truck land speed record in a diesel Dakota.Who's to say?
Nissan Mike is online now   Reply With Quote
Old 04-24-2008, 05:06 AM   #29
BrianCMM
BrianCMM's Avatar
No one got flamed for wanting an answer to a question. It was for coming on this forum that has such a wealth of knowledge and helpful people and basically telling everyone to shut the hell up or answer the question.
As is he is owed something. And to have that as your third post! Not exactly the best way to get people to help you. If everyone had that attitude, this forum would lose a lot of helpful people.
User Name
Password
Search this Thread:
Advanced Search
vB code is On
