Re: Removing door panels
Check out that armrest. Believe it or not it lifts straight up. You can try pulling on it but you'll prolly just break the clips. Instead, hit it in an upwards motion with the meat of your palm (right where it meets your wrist). Start kinda easy and then build up the force until it pops off. One of my doors is a piece of cake, the other I have to hit that thing pretty hard.
Also on the handle there's a chunk of SOFT plastic wedged in there. Gently work a very small flathead into there and pry it out. You can place a rag behind the screwdriver to protect the handle or do like I do and just stick your finger in there and use your finger as the pivot point. After that its just a few screws and then sliding your fingers behind the panels to pop out the clips. I've had my panels off numerous times and almost never break a clip even though I don't use a tool. Just gotta slide your fingers as close as you can to the next clip and then push off the door w/ your thumb to get a good solid pull.
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
