Re: how to remove grill
It's been a while, but from what I remember: If you look closely into the grill you will see these plastic square screw heads that you need to rotate with a flat head screw driver. There are several that you need to turn and pull the grill away as you do it. These are actually clips that once the grille is removed, you need to remove from the core support and reinstall on the grille in order to reinstall the grille itself. Make sense? Probably not, maybe someone else with a better explaination will come along.
-Counsel Yourself
2009 Blizzard Pro-4X
