Old 09-24-2006, 01:44 PM   #1 (permalink)
src4usarmy's Avatar
Under Hood Light Mod
First, you can choose to whatever kind of switch and lights you want. I ran my power wire directly from the battery to the hole behind the hinge up through the hood to both of the lights. The first pic is where the wire goes into the hood and the second is where I mounted the lights. I am going to change the lights because I chose to use a mercury switch and it works by making and breaking the ground connection and the lights are already grounded by the screws. All of the holes I used except for the screws in the lights are already in the hood. I chose to solder all of my connections and use shrink tubing on that to make a good connection. Next you mount a mercury switch about midway up the hood in one of the two small holes and pop the plastic clips from the insulation under the hood to run one of the wires to the ground side of the lights and the other wire from the switch goes to ground somewhere. You could choose to use a manual switch like the pic below or a Hood Pin Switch in the hole beside the battery but I like the mercury switch. The mercury switch run me about $6.00 and I've seen the hood pin switches on the internet for under a dollar. So all you need are some lights (your choice) and some wire. First time I've done this so any suggestion or something I forgot, or questions just let me know.
under-hood-light-mod-111_5857.jpg  under-hood-light-mod-111_5854.jpg  under-hood-light-mod-111_5856.jpg  under-hood-light-mod-111_5858.jpg  under-hood-light-mod-111_5861.jpg
src4usarmy is offline   Reply With Quote
Old 09-24-2006, 02:34 PM   #2 (permalink)
baseballfanz's Avatar
Re: Under Hood Light Mod
Good stuffs, thanks.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 11-10-2006, 08:00 PM   #3 (permalink)
Where did you buy your mercury switch? Radio Shack.
Thanks,
Robert M.Kricko
Greeneville, TN
rkricko00 is offline   Reply With Quote
Old 11-10-2006, 08:36 PM   #4 (permalink)
Brundy's Avatar
Another good light is GM's underhood light that has the wind-up cord and switch built in.
Brundy is offline   Reply With Quote
Old 11-14-2006, 12:16 PM   #5 (permalink)
src4usarmy's Avatar
been out of town but sent ya a pm of the local shop.
Map Light/Room Light Bulb No.? bradld2004 Titan Parts & Accessories 2 03-03-2007 07:24 AM
Window lock button. Light or no light? biggieb22 Titan Problems & Dealer Service 8 02-22-2006 02:12 PM
hood light samauri1 Titan General Discussion 19 01-26-2005 11:11 PM
Under hood light...where is it? Treebasher Titan General Discussion 11 10-03-2004 11:47 AM
Under hood light Bayou Titan Titan General Discussion 1 01-29-2004 09:17 PM
