Old 12-15-2006, 02:31 PM   #1 (permalink)
Need remote start & alarm diagram
Hi,
I was wondering if any one might have a remote start/alarm diagram for 2006 titan king le. I am installing a viper all in one and can't seem to find it on google. I have everything I need, including the DEI immoblizer interface. Any help would be much appreciated.
Thanks,
Jeff
spyder6166 is offline   Reply With Quote
Old 12-15-2006, 11:49 PM   #2 (permalink)
Re: Need remote start & alarm diagram
any one ???????????????
Old 12-15-2006, 11:56 PM   #3 (permalink)
gabriel c.'s Avatar
here you go same for the 06, double check every wire with your dvm.
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2005 / Remote Start
[PRINT THIS PAGE]
12volts green (40A) + ignition harness
Starter brown + ignition harness
Second Starter lt. green or blue/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory purple + ignition harness
Keysense red/blue to black/red + ign harn or BCM R of column, pin 37
Power Lock blue - driver door module in door
Power Unlock red (double pulse) - driver door module in door
Lock Motor purple 5wi BCM to right of column, pin 65
Unlock Motor green 5wi BCM to right of column, pin 59
Parking Lights+ red/blue + dimmer switch on dash
Parking Lights- N/A
Hazards white/black - BCM to right of column, pin 29
Turn Signal(L) green/black + BCM to right of column, pin 60
Turn Signal(R) green/yellow + BCM to right of column, pin 61
Reverse Light green/white + inside rearview mirror
Door Trigger see notes - BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is red/blue in pin 12. The LR door trigger is red/yellow in pin 48. The RR door trigger is red/white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision blue - BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use red/white in pin 62 at the BCM.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire red/green or red/black + brake pedal switch
Parking Brake green - parking brake switch or cluster
Horn Trigger red/white - horn switch
Memory Seat 1 lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
Door Lock Interface Required:
No Type:
Data Bus
Part #: IM-Nissan-1
Notes:
Smart Starter Kill Relays: Not Available
warning
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
third coast titans
gabriel c. is offline   Reply With Quote
Old 12-17-2006, 02:53 PM   #4 (permalink)
Thank you very much I will be installing my combo unit next week.
Old 12-17-2006, 06:04 PM   #5 (permalink)
gabriel c.'s Avatar
no problem.
third coast titans
Old 02-28-2007, 10:59 PM   #6 (permalink)
RyanF's Avatar
Does anyone know if the Data Bus Vehicle interface kit from bypass.com is a good buy for our truck? Im looking at the XK02. Does this plug right into the truck wiring harness then connect right to an alarm? I guess I'm asking if it makes install easier, instead of running wires everywhere?
RyanF is offline   Reply With Quote
Old 02-28-2007, 11:11 PM   #7 (permalink)
[quote=spyder6166]Hi,
Thanks,
Jeff[/QUOTE
I'm having considerable probs with my Viper system right now. (work truck, not Titan truck) FYI...mainly inside temp control module temp and auto start. ...I have GPS tracking on the Titan and factory alarm..if my truck is ever stolen I just call GPS and report the location ...works like a charm..most heavy machinery companies are doing it out here on their heavy equipment rentals..theft is a big problem out here.
CdnTitan LE 4x4 is offline   Reply With Quote
Old 03-09-2007, 08:26 AM   #8 (permalink)
timlahr's Avatar
How was it to workaround the security chip in the key? I wanted to put a remote start system in and the installer said he would have to permanently install a key near the igniton switch so the vehicle would start without it. I did not like the idea of that.
TIm
timlahr is offline   Reply With Quote
Old 03-09-2007, 10:27 AM   #9 (permalink)
baseballfanz's Avatar
TIm
No work around that, if you have the transponder in your key you need to bypass that featur by having a key pemanently in the truck, usually hidden inside the bypass box.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
WTB: alarm sytem w/remote start blackandwhite Buy/Sell 0 10-30-2006 06:57 PM
remote start plus alarm supertitan Titan Parts & Accessories 12 05-04-2006 09:25 AM
Remote start/Alarm, which brand do you like and why? NickSimcheck Titan General Discussion 18 12-07-2005 07:17 PM
alarm and remote start smokespeedtitan Titan Interior Discussion 11 02-28-2005 10:15 AM
