Old 03-18-2009, 11:37 PM   #16 (permalink)
src4usarmy's Avatar
Re: How to install remote starter
Originally Posted by Mighty Whitey Titan View Post
Thanks for your help. Did you just tap in to the purple wire. You dont have to run it through the relay. And I take it the blue wire on your remote start is the activation imput. Mine is Yellow brown so I will use that. So I and going to take wire and hook it to 30, and 85, Run these wire to ground, Than take 86 and tap off the purple wire for this. They Hook my yellow brown to my 87 terminal. Now I should have a - pulse wire. ? Thank you. Let me know if I am hearing you wrong. Again thanks for the great detail.
I don't know how your remote starter needs to be hooked up because it may be different from mine but the way mine is setup for the starter to start the truck by using the factory fob and hitting the lock button my starter needed to receive a signal from the lock wire and it had to be neg. but that purple wire sends out a pos. pulse. The only thing the relay is for is to change that pos. pulse to a neg. pulse that is going to the remote starter. The wire from my remote starter that received the signal was a blue wire but your may be different, just follow the directions and you should be good.
src4usarmy is offline   Reply With Quote
Old 03-24-2009, 10:10 PM   #17 (permalink)
Banned
crisiamhe's Avatar
Send a message via AIM to crisiamhe
thank you very nice write-up
crisiamhe is offline   Reply With Quote
Old 03-25-2009, 11:10 PM   #18 (permalink)
src4usarmy's Avatar
no problem
Old 03-27-2009, 08:04 PM   #19 (permalink)
Banned
crisiamhe's Avatar
Your writeup was so good that I ordered a Directed Autostart System off Ebay for $21.50 shipped and will follow ur directions I'll let u know if I am successful
thanks again
Remote Start and Install LANDMAN Texas Forum 11 09-01-2006 07:29 PM
anyone have instructions for installing alarm or remote starter ucf_motorcycle Titan General Discussion 4 05-25-2006 08:56 AM
Nissan Remote Starter Luckyontheducky Titan General Discussion 29 02-01-2006 06:54 AM
Remote Starter BiXLL Titan Parts & Accessories 23 10-31-2005 11:15 AM
Who has a remote starter??? PuvMan Titan General Discussion 9 05-24-2005 03:21 AM
