Old 04-04-2007, 05:14 PM   #16 (permalink)
Adanac's Avatar
Re: Fog Light Mod - On with or w/o parking lights - simple
I have the Daytime running lights on my truck. Would it be possible to wire the truck so that my fogs come on instead of the DRL. I know that the DRL power the high beams at a lower intensity. Would i need to increase the power going to the fogs? By doing this, I could still use the fogs when putting on my normal head lights cause the DRL shut of when the normal lights are on. All I nead to do is light up the fogs with the switch on the stock like I normaly do.
04\' Gold SE KC 4X4
Captain seats, Big Tow, Off Road package, Utility Bed, Fog Lights, OEM Bug Shield, Tube Steps, Remote Start, Sylvania Silverstar Ultra
Adanac is offline   Reply With Quote
Old 05-16-2007, 08:04 PM   #17 (permalink)
Does anyone know the size of the fog light bulbs. I would like to replace them with PIAA or some super white like I did in the headlights and high beams.
troutstitan is offline   Reply With Quote
Old 05-17-2007, 09:02 AM   #18 (permalink)
baseballfanz's Avatar
Here's a chart of all bulbs.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 05-18-2007, 07:11 PM   #19 (permalink)
Thanks greatly for the part numbers. LOve this sight and the good people on it!
Old 05-24-2007, 07:41 PM   #20 (permalink)
Thanks for the thumbnail picture but stores could not find a match for the HID fog light replacement bulbs. Does any one know where I can buy some from it's an 07 although I believe aall years are the same. Any feedback on different colors? I am proably wanting to stick with a bright white or blueish light.
Any help or opions would be great thanks
Thank a Vet this week!!!
Old 08-05-2007, 04:04 PM   #21 (permalink)
grnTitan04's Avatar
Did this mod over the weekend... Sort of...
I changed a couple things that I think makes it even easier, and continues to use more of the factory parts.
Take a look at this thread for the Improvements
grnTitan04 is offline   Reply With Quote
Old 04-11-2008, 02:47 PM   #22 (permalink)
Down South's Avatar
will they stay on with the brights on
Down South is offline   Reply With Quote
Old 04-23-2008, 05:05 PM   #23 (permalink)
BLUEDEMON's Avatar
Lightbulb Re: Fog Light Mod - On with or w/o parking lights - simple
If you want a great HID kit for your fogs go here they have awesome kits at great prices!!
cqlight.ca
BLUEDEMON is offline   Reply With Quote
Old 11-11-2008, 09:23 AM   #24 (permalink)
Banned
There has to be an easier way of doing this... My husband did this mod to his 96 Civic and all he had to do was switch two wires on the main harness plug.... I will see if I can have someone figure this out.
SiMpLyMoDiFiEd is offline   Reply With Quote
Old 01-09-2009, 12:15 PM   #25 (permalink)
PondTunes's Avatar
Yet another variation on the fog/driving light mod. This one requires no cutting of the factory wires and retains some of the stalk functionality.
Fog Light Mod by Pondtunes
PondTunes is offline   Reply With Quote
Old 05-13-2009, 07:38 AM   #26 (permalink)
SATXTITAN's Avatar
Ok guys just to make sure. With this mod, if you want your fogs to turn on anytime you will supply direct fused power from the battery to both #30 and #86 on the relay correct? Then #85 will go to the light stock, #87 to the white/red stripe fog light wires, and #87a will be unused capped? Another question is if I connect direct battery power to both the #30 and #86 on the relay, will I need to use a seprate inline 20 amp fuse for the #86 on the relay? Or will one 20 amp fuse work for both the #30 and #86? I hope I didn't confuse you guys, although I think I confused myself. :-)
SATXTITAN is offline   Reply With Quote
Old 05-18-2009, 06:40 PM   #27 (permalink)
Whoa! You confused me alright - and I haven't done this mod in years! Still working like a champ, tho! Right now I'm away from home (in the Bahamas! ), and I'd have to take a look at my truck and the diagrams. I do know that if you follow my instructions and the diagrams, this mod will allow you to turn your foglights on and off anytime, regardless of if your headlights or foglights are on or off.
Regards,
DipStick
2006 Radiant Silver Titan SE 4WD
True-Dualled Flowmaster 40's
AEM Brute Force Cold Air Intake
2* Timing Advance
PRG 2" Leveling Kit
Fog Light Mod - On anytime <== Click for the HowTo...
Stainless Nerf Bars
Throttle Body Bypass
Keyless Entry Keypad
DipStick is offline   Reply With Quote
Foglights on with parking lights baseballfanz Titan General Discussion 61 01-16-2007 07:47 AM
Parking Lights WITH FOG LAMPS!! BigRedTitan Titan FAQ & Howto Area 25 09-29-2006 11:24 PM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 08:06 PM
Fogs w/ Parking Lights ATitan4Me Titan Interior Discussion 5 03-12-2004 10:01 AM
