Re: i need wiring diagram for power window switches
tried to do it but because the switches have auto up and auto down they dont act likeregular switches da and is hard to locate correct switches....you need the switchs and wiring harness just to try to find out if it will work.....dont bother just install aftermarket window kit with switches from a1electric.com as far as power door locks the BEST way i found is to order the le door lock from nissan...save your self time and pain. do not you cable lock kits, not worth the trouble. splicing in to your cable is not good nor is easy. if the splice is not perfect...i mean perfect it will never work or not last long...i tried it and i removed them and bought the nissan locks wow much better install and flawless operation. hope it helps
What are the part numbers for everything i need from the le door locks to have it working. And links would be cool too. Thanks
1. i had to solder two wires to two little tabs to power up these unit unless you want to spend more to get the whole door wire harness. once you soilder the two wires works prefect.
2. the passenger door will no longer work or need a key hole because it dosen't have the use of it so order the blank cover for the door handle key hole.
you can find all these parts at www.courtesyparts.com . ships fast and they have every part you could ever want with out going to the dealer in person.
you can find all these parts at ships fast and they have every part you could ever want with out going to the dealer in person.
hope this helps
Thanks alot for the part numbers.
Can you better explain the what wires you had to tap and where to solder.
one lock has only two tabs...solder one wire to each tab(thinks its the passenger side lock.
drivers side has five tabs. solder two wires to the same tabs as the passenger side. just count the black tab spaces on the passenger side and you'll know which two are the ones for the drivers side.
the locks come only with locks...no switches no wires nothing but lock unit...i ordered switches from a1electric.com.
i hooked up my alarm to the door locks using two relays and got keyless entry.
holla if you need more help. i know did at first and i came here.
i did cable locks at first..boy what a mistake...get the nissan parts...
