Old 02-04-2008, 09:39 PM   #1 (permalink)
RyBo's Avatar
Send a message via AIM to RyBo
8" Lift With 3" Body?
Hello everybody...well I decided to stick with this setup for awhile now and D-Days coming up for the install. But I was just wondering, with CST's 8" lift how difficult is it to add a 3in body on top of it? Does th body lift rest on top of the spindle, or is it in a totally different spot?
First time lifter, quite new at this
Thanks,
Ryan
RyBo is online now   Reply With Quote
Old 02-04-2008, 09:44 PM   #2 (permalink)
Sammy Sandbag's Avatar
Re: 8" Lift With 3" Body?
Body lift is just that, it lifts the body off the frame. All the body mounts are replaced with taller ones. I wouldn't recommend it. Leaves gaps, everyone sees more of your frame. Your bumpers have to be lifted or you have an ugly gap. Your hitch hangs down low, and your spare tire becomes very visible. The radiator shroud has to be modified, as well as the steering linkage (on most body lifts.)
-Counsel Yourself
Old 02-04-2008, 09:53 PM   #3 (permalink)
RyBo's Avatar
Thanks sammy! yea I've heard many mixxed things about body lifts. A few friends of mine have Titans with body kits and they havent had a single problem, they just installed those gap guards and torqued up the spare tire a bit and looks pretty damn good to me...though a 2.5 inch leveling kit is also a consideration, do you think i should do that instead?
I'd rather not get BP's system or FTS's 15" Lifts because they're like gagunda big so i think 10.5 or 11in should be JUST fine...
Thanks again for your imput Sammy...
Old 02-04-2008, 09:57 PM   #4 (permalink)
Is your truck a 2WD or 4WD?
I noticed you plan on 35" tires, is there a reason you want more than 8" of lift?
-Counsel Yourself
Old 02-04-2008, 10:28 PM   #5 (permalink)
RyBo's Avatar
2WD...Well I didn't know if there was a superior difference between 37's and 35's. I do my fair share of off-roading and I have a feeling those 37's would rip my fenders off if I did any flexing, sio I thought 35's would be just the right fit, but I think im going to go with PRG's leveling kit and the 8in CST with 35" Tires...WAY cheaper and looks like a better buy...
Old 02-04-2008, 10:34 PM   #6 (permalink)
Yellomantis's Avatar
If you get the fabtech lift, PRG can get you over 10" of ALL suspension lift with it.
www.myspace.com/yellomantis
Old 02-05-2008, 12:47 AM   #7 (permalink)
10"+ of lift and 35"s is going to be a whole lotta wheel well, not good looking IMHO.
-Counsel Yourself
Old 02-05-2008, 04:06 PM   #8 (permalink)
RyBo's Avatar
Well would I be able to roll 37's under that? Because I plan on offroading and flexing is a big concern...I can lower the saws and the truck would sit at about a regular 8 in height, which works well enough for me...but yes i completely agree, too big of a lift and too small of tires looks rather hokey and cheap, not a good look at all...
And yellowmantis, how could the 6in be raised up to 10? I didn't think coilovers or blocks could do THAT much...
Old 02-05-2008, 04:52 PM   #9 (permalink)
Search for Austin's truck. He was an old member with the "special" Fabtech lift and 37"s. He's got a webpage (at least he used to) with tons of pictures and how-to's.
-Counsel Yourself
Old 02-05-2008, 04:54 PM   #10 (permalink)
Something that Greg does with a combination of parts. I'm not sure what parts are involved, so I won't speculate. I would highly suggest calling him.
Old 02-05-2008, 04:58 PM   #11 (permalink)
CBURNS1101's Avatar
I had the same setup running 20's on 37's and loved it but decided to go bigger
8-lift-3-body-titan3.jpg  8-lift-3-body-titan1.jpg  8-lift-3-body-i-p1010112.jpg
CBURNS1101 is offline   Reply With Quote
Old 02-07-2008, 09:41 AM   #12 (permalink)
RyBo's Avatar
Nice truck there CBurns! So Would you reccomend going for the 3in body lift? Or would I still be able to fit 37's if I got the leveling kit instead? =/
body lift "kits" afailedutopia Titan Suspension 1 03-09-2007 09:05 PM
6" pro comp + 3" body lift?? afailedutopia Titan Suspension 6 03-08-2007 02:33 PM
Anyone running 6" suspension and 3" body lift combo?? Pics if possible... quiksilver titan Titan Pictures & Media Post 9 05-31-2006 08:17 PM
3" Body Lift pi3yeargrad Titan Parts & Accessories 3 10-11-2005 10:47 PM
3" Body lift SmoKedOuTtiTan Titan Suspension 11 04-22-2005 09:35 AM
