Re: Installation of SAW's, Traction Bars, UCA's and Cambolts
IIRC, the hats are not through-bolted. So the bolt will hit the bottom of the tapped hole before it's tight, I believe. Definitely call Greg in the morning. He'll get the new bolts out to you quick, I'm sure.
Just finished up my install today. Driverside front kicked our a$$, we weren't really paying attention to any directions and ended up doing some unnecessary steps. We flew through the rest of the install though, passenger side shock and uca and rear shock and block took only about 2 hrs. Thanks BB for detailed instructions and pics, they definately helped me out.
__________________ 2006 KC SE 4x4 Galaxy Black Big Tow, Captain's chairs
XD HOSS 20x9, BFG A/T KO's LT305/55-20, PRG Performance Pkg. w/ SAW's, NISMO exhaust, Volant Powercore CAI, Inalfa sunroof, EBC Sport rotors, EBC Green Pads, Boston Acoustics SX60, Boston Acoustics S65RC, Boston Acoustics GT-50 amp, Boston Acoustics G1's(2) Tech12 box, Truxedo Lo-Pro Tonneau, 20% tint, Weathertech window vents, Weathertech floor liners.
Hows the ride? Were you surprised at all with the ride?
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's, Two 12 volt tech underseat subs with CDT 4100 and cdt replacment door speakers,MD DVD player with 8.5 screen Shift Pass You
awesome write up
'04 4WD SE TITAN - DAILY DRIVER
'05 4WD LE FRONTIER - WIFES WHIP
'70 SS MONTE CARLO - TOY #1
'64 SS CHEVELLE - TOY #2
'92 ALFA ROMEO - WIFES TOY
Very nice write up. Just curious what you paid for this setup. It looks great, a lot better than just a leveling kit. And sounds like it would be worth it when you talk about the difference in ride and feel of the truck. Interested..
2006 SE 4X4 Crew Cab
Leveling Kit 2* Timing Advance BFG 285/65-18 ATs Magnaflow Dual Cat-Back Detroit TrueTrac AEM Brute Force CAI Moto Metal 957's Bully Dog PP
I couldn't get the driver side upper a-arm bolt off for the life of me. Mostly because my 19mm open wrench was a pos. So I disconnected the steer shaft and was able to get a socket in there. Was this a bad idea? I reconnected it the same way it came off. Also a dumb question but I got to ask, is there any difference between the left and right prg's a-arms? I don't see any markings and they both look identical.
Thanks man. Oh and i'm using your write up to install mine and it's going good so far. Just about done with the driver side and I will start the passenger side tomorrow. Your write up is helping out a lot. Thanks
I got the lift on. The install wasn't too bad. It was a little difficult getting the coil hats on. If those 3 screws were just 1/4" longer it would have been a lot easier. Your write up helped out a lot. I used all your torque specs except for the uni-ball bolt, I torqued it to 100 ft lbs. 58 ft lbs seemed a little low to me and since there is no cotter pin with these a-arms i didn't trust 58 ft lbs.
I took it for test drive and it handles great. I have the sway bar off right now and I think I might put it back on. It seemed to sway a lot on the turns.
Glad you got the suspension on.... Although I'm concerned about your overtorqueing the spindle nuts....
Trusting "my" numbers isn't the issue... They're Nissan's numbers. I know what happens when torque is misapplied. Do you?
I see it everyday in my profession. As an Engineer, I understand what torque is and what it does. When you torque something, you are actually stretching the bolt. Now, you applied almost twice the specified torque to the spindle threads. Granted, they are rated much higher, but there's a reason they are to be torqued to only 58 ft-lb.
You may have an issue, but most likely you won't. We all know how "over-designed" Engineers make things. Hope it works out for you!
I read PRG's Upper A-Arm Installation Notes and it says tighten to 100ft/lbs. Does Nissan recommend 58ft/lbs on the stock spindle bolt and Greg recommend 100ft/lbs on his bolt because the new bolt is stronger?
Also, do you know why their is no cotter pin on the new spindle bolt?
