Old 03-25-2008, 12:18 PM   #1 (permalink)
tintintin's Avatar
removal of brake dust
What's a good way to remove brake dust, I have used brake cleaner and it's a mess!
tintintin is offline   Reply With Quote
Old 03-25-2008, 02:04 PM   #2 (permalink)
Send a message via ICQ to PuvMan Send a message via AIM to PuvMan Send a message via MSN to PuvMan Send a message via Yahoo to PuvMan
Re: removal of brake dust
what are you trying to remove brake dust from?
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
Exhaust
PuvMan is offline   Reply With Quote
Old 03-25-2008, 02:10 PM   #3 (permalink)
Snakes's Avatar
Next time you change your brakes, get ceramic brake pads. Little to no break dust at all and they work the same maybe even better, but thats my opinion. I use them, I LOVE EM!
If you ain't FIRST your LAST!
Snakes is offline   Reply With Quote
Old 03-26-2008, 05:41 AM   #4 (permalink)
tintintin's Avatar
trying to eliminate it from interior and exterior portion of the wheel!
Old 03-26-2008, 05:43 AM   #5 (permalink)
Banned
roy365's Avatar
Hire some one else to do it? There isnt a real clean way to remove brake dust. If you figure it out let me know.
roy365 is offline   Reply With Quote
Old 03-26-2008, 06:37 AM   #6 (permalink)
grnTitan04's Avatar
Nothing is amazing at removing brake dust, regular soap (like simple green) will work but you are going to need a brush.
If you can find it, BB Brute Cream Cleaner is pretty good stuff. It is actually a bathroom cleaner, but works surprisingly well on brake dust for whatever reason.
Improvements:
NCD Level Kit|K&N Drop In|Magnaflow muffler|Step Tubes|Reese Hitch|Husky Liners
Nitto Terra Grapplers 285/70/17|Extang RT Tonneau|RadFlo Remote Res Rears
OEM Hood Deflector|Hayden 405 Transmission Cooler
Air Box mod|Improved Fog Light Mod|dba 4000 series rotors, Akebono ProACT pads
Axle Vent Mod
Fluids, Etc.:
Engine: Penzzoil Platinum 5W-30, K&N HP1010 Oil Filter, K&N 33-2286 Air Filter
Differentials: (F)Royal Purple 75W-140, (R)AMSOil 75W-140
Transmission: Castrol Multi-Vehicle Import
Wish List:
Air Horn, RadFlo 2.0 Coilovers, AEM Brute Force CAI, TruTrac, Bass boat...
Donations graciously accepted.
grnTitan04 is offline   Reply With Quote
Old 03-26-2008, 07:09 AM   #7 (permalink)
BK19702's Avatar
I'll echo the simple green with a brush for the wheel. I had a Bronco that was plagued with brake dust on the front wheels. The only way to get them sparkling again was with the simple green and .25 oz of elbow grease. The elbow grease is located down the aisle from the blinker fluid and cross drilled brake lines in the auto parts store, by the way.
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 03-26-2008, 07:43 AM   #8 (permalink)
Banned
roy365's Avatar
[quote=grnTitan04]Nothing is amazing at removing brake dust, regular soap (like simple green) will work but you are going to need a brush.
If you can find it, BB Brute Cream Cleaner is pretty good stuff. It is actually a bathroom cleaner, but works surprisingly well on brake dust for whatever reason.[/QUOTE]
Well there's an oddity. Must be citrus based?
I can hear the slogan...."makes truck owners crazy, and house wives lazy"!!!!
Old 03-26-2008, 08:36 AM   #9 (permalink)
Quartz's Avatar
I just use what ever commercial car wash concentrate I have on hand, with some water and a soft sponge. Works well for me.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 03-26-2008, 09:50 AM   #10 (permalink)
Skyboi's Avatar
If you're talking about a factory wheel...I clean my '07 SE factory wheels with a "NON" acid airconditioning coil cleaner. It doesn't react with the plastic coating,and cleans the inside wheel clean enough to eat off of.
Application:
1. Mix one part NON ACID COIL CLEANER with 3 parts water in a spray bottle
2. Rinse wheel with water and do not do in direct sunlight (never spray products on wheels in direct sunlight...UV reaction)
3. Spray liberally on wheels and count 30 - 45 seconds
4. Rinse
5. Repeat if really bad
6. Bond is broken ....wash by hand using mit and soft bristle wheel brush...Dry with leaf blower
Good luck...Other detailing tips posted in the Detailing forum
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 03-26-2008, 09:52 AM   #11 (permalink)
Supporting Vendor
P's Titan's Avatar
Adam's All Purpose Cleaner will work. They are a site sponser
www.adamspolishes.com
Old 03-26-2008, 11:57 AM   #12 (permalink)
Brents's Avatar
I use Shout it seems to work better than Simple Green. Shout also works well on white letter tires and in the engine area. You still have to rub a little for the wheels and tires.
Brents is offline   Reply With Quote
Old 03-26-2008, 04:09 PM   #13 (permalink)
Yellomantis's Avatar
If it's the OEM wheels, call me crazy, but I have used 0000 steel wool and spray detailer with great results. As a bonus, it removes light scratches too!
The idea was reccomended to me by a co worker who refinishes high end furniture on the side... Here's the stuff I have:
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
www.myspace.com/yellomantis
Old 03-26-2008, 04:51 PM   #14 (permalink)
Skyboi's Avatar
Mantis..Please...God no!...not on plastic coated mags....I'm beggin' no... That's it I'm comming to Kalifornia to polish your mags.
I'll need plenty of alcohol and a bevy of bikini wearing hardbodies to get started.
Pop Pkg * Tow Pkg
Fogs
Old 03-26-2008, 10:15 PM   #15 (permalink)
The funny thing is, it actually worked! This steel wool is sooooo fine, it feels like cotton gauze. It even took off all the overspray I had on the wheels too!
brake dust five011 Titan Wheels, Tires & Brakes 20 11-07-2006 11:58 AM
Brake Dust soonertitan Titan General Discussion 23 03-31-2006 02:17 PM
Does the final Brake means no more brake dust? K-MU Titan General Discussion 17 07-06-2005 06:17 AM
GD brake dust!! textitaninva Titan General Discussion 30 05-05-2005 07:41 PM
brake dust floridacrakr Titan Problems & Dealer Service 16 11-17-2004 07:22 PM
