Old 11-21-2008, 05:04 PM   #1 (permalink)
Radiator Removal Lots of pics and step by step
After my trans cooler (inside radiator) busted i had to replace my radiator. After searching for a little while i saw that nobody has started a thread with pics and full instructions so i will be the first. Everything that has to be removed (nuts, bolts, clips) are either circled in red or has an arrow pointing to it. Whenever i was removing the radiator i referenced the technical maintenance manual (pdf file). I have 5 individual posts to make so please do not post any responses until the last step of the radiator being removed. Thanks
Tools Needed
drain pan
10mm socket
8mm socket
socket wrench
8mm wrench
10mm wrench
flat tip screw driver
crescent wrench
pliers (regular not needle nose)
Keep in mind that i was referencing the technical maintenance manual and i am translating that into my own words.
Step one
A) Remove the engine cover.........2 10mm bolts right in front.
B) Remove the air cleaner and air duct assembly.........unclip clips by air filter, unclip electical line that is connected to the assembly as well as the plastic retainer holding the wires, then unscrew the clamp holding the air assembly onto the throttle body.
C) Drain coolant from the radiator.............located underneath on the passenger side....make sure your drain pan is underneath and that the coolant is hot
radiator-removal-lots-pics-step-step-11-engine-cover.jpg  radiator-removal-lots-pics-step-step-12-air-assembly.jpg  radiator-removal-lots-pics-step-step-13-coolant-drain.jpg
boggs0214 is offline   Reply With Quote
The Following 8 Users Say Thank You to boggs0214 For This Useful Post:
BBtruck (11-18-2009), EseLoco918 (09-29-2009), jdl75 (06-01-2009), Kronos1965 (04-17-2009), O-FiveCC (04-16-2009), patman (11-22-2008), Roodogg (06-23-2009), sudden urge (11-25-2008)
Old 11-21-2008, 05:10 PM   #2 (permalink)
Re: Radiator Removal Lots of pics and step by step
Step Two
A) Disconnect the automatic transmission fluid cooler hoses.........there are two clamps that the bottom of the radiator (one on driver one on passenger). Note - if you would like to keep your transmission fluid be sure to clamp the two hoses so the fluid doesnt leak out
B) Disconnect the radiator upper and lower hoses........upper is under the hood on the left of the radiator cap and the lower is underneath on the passenger side.
NOTE - all fluid will not be removed from the radiator so whenever you are disconnecting the lines ensure that you have something to catch the fluids with.
radiator-removal-lots-pics-step-step-21-transmission-lines.jpg  radiator-removal-lots-pics-step-step-22-upper-hose.jpg  radiator-removal-lots-pics-step-step-23-lower-hose.jpg
The Following User Says Thank You to boggs0214 For This Useful Post:
Old 11-21-2008, 05:15 PM   #3 (permalink)
Step Three
A) Remove the lower radiator shroud.....three clips located underneath....once they are uncliped move shroud towards fan and slide downward
B) Remove the upper radiator shroud bolts..........move shroud towards fan and pull up
radiator-removal-lots-pics-step-step-31-lower-shroud-clips.jpg  radiator-removal-lots-pics-step-step-32-radiator-shroud-bolts.jpg
Old 11-21-2008, 05:18 PM   #4 (permalink)
Step Four
A) Remove the the air condition condenser bolts and brackets.........there are two located underneath a plastic covering.....pull the covering back to expose and try not to lose the bold.....kind of tricky if you have large hands.......also ensure you locate the brackets because they are just pressed in with rubber gromets
radiator-removal-lots-pics-step-step-41-condenser-bolts.jpg  radiator-removal-lots-pics-step-step-42-condenser-bolts-2.jpg
Old 11-21-2008, 05:30 PM   #5 (permalink)
Step Five
A) Remove all lines from the radiator.......the one on the right in the picture was hiding from me so i snapped a picture of it.....it is right by the coolant resivor (passenger side)
B) Begin to slide the radiator out........you will see that the a/c condenser will get bound up on the radiator when trying to remove it......i just simple asked the wife to reach into the lower bumper inlet and pull it towards her and just wiggled it out.
C) Remove the external radiator cooler from the radiator itself........two bolts on to and slides into grooves at the bottom.
Note - You can see that i took the radiator out with the fan still installed.........it can be done but scraped up the fins on the radiator as you can see in the picture so i would suggest that you remove the fan as well. The fan removal must be done with a 10mm wrench and has 4 nuts holding it on. I didnt snap a pic of it but they are gold.....you cannot miss them
I have actually never replace a radiator before but i am pretty mechanically inclined so i tried to make this HOW TO post the easiest that i could for almost anyone the remove their own radiators and not get caught at the dealership paying over $1000 for the parts and labor. Hopefully this will help everyone out that has already order the all aluminum Stillen radiator and that have to wait like myself. If I recall it took me about an hour to do the whole process, take notes on everything, and take pictures. Without doing all that it probably would have taken me 30 minutes. This is actually a really simple process and with the right tools I just gave you all the information that you need to accomplish it.
radiator-removal-lots-pics-step-step-51-transmission-cooler-line.jpg  radiator-removal-lots-pics-step-step-52-img_0735.jpg  radiator-removal-lots-pics-step-step-53-radiator-trans-cooler.jpg  radiator-removal-lots-pics-step-step-54-scraped-fins.jpg
The Following 17 Users Say Thank You to boggs0214 For This Useful Post:
(o)(o)'n Beer (08-20-2009), BBtruck (11-18-2009), bestatchess (11-21-2008), CL 8 2WD (10-11-2009), EseLoco918 (09-28-2009), hooligan (02-22-2009), HRTKD (11-21-2008), Kronos1965 (11-21-2008), leonag123 (02-08-2009), NorCal 4x4 (11-22-2008), O-FiveCC (04-16-2009), pedalhappy1053 (11-27-2008), RobKar (11-21-2008), roy365 (11-21-2008), royr (05-24-2009), SCedTITAN (07-06-2009), TecheTitan (05-05-2009)
Old 11-21-2008, 05:33 PM   #6 (permalink)
themaildude's Avatar
Thanks for the write-up with pics.
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 11-21-2008, 05:34 PM   #7 (permalink)
thanks for waiting until i was done.....i didnt want anyone to have to go searching through posts and replies looking for all the steps
Old 11-21-2008, 05:39 PM   #8 (permalink)
RobKar's Avatar
Nice ... ....
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 11-21-2008, 06:41 PM   #9 (permalink)
Banned
roy365's Avatar
Thanks a lot!!!!
Pictures are always good!!!!!
roy365 is offline   Reply With Quote
Old 11-21-2008, 06:54 PM   #10 (permalink)
Kronos1965's Avatar
Well-documented and detailed from a "regular" guy.
Very much appreciated as I will be buying a Stillen radiator at the first of the year...
HippieWhore™
Kronos1965 is offline   Reply With Quote
Old 11-21-2008, 09:12 PM   #11 (permalink)
HRTKD's Avatar
Nice writeup! So the Stillen radiator won't get to you until next month, right?
Jim
Old 11-21-2008, 10:59 PM   #12 (permalink)
titanss's Avatar
Great Write Up!!!
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
Old 11-21-2008, 11:03 PM   #13 (permalink)
travelship's Avatar
Very nice writeup, I'm bookmarking this thread for when I need it.
You could just make 5 quick posts when you start the thread, and then go back and edit them to add the info.
04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
travelship is offline   Reply With Quote
Old 11-24-2008, 08:37 PM   #14 (permalink)
loufish's Avatar
First off. great job!...Good pics also...
Second...did you notice how big the Titan radiator is?
Same goes for the trans cooler....that is a big cooler!
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 11-24-2008, 09:00 PM   #15 (permalink)
walleeme's Avatar
Nice write up.
Thank you.
A couple months ago now, my buddy changed out the radiator in his 04, and he said it took kin 6 hours.
Just waiting now, until I have to do mine, or one of my buddies.
I bookmarked the thread in my favorites.
My has almost nothing compared to some of you guys, but I still like it.
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing at least half your clothes.
Let him that hath understanding count the number of the beast: for it is the number of a man; and his number is Six hundred threescore and six.
Iron Maiden
Integrity is someting you cannot buy. You either have it, or you don't. You do not want to not have it.
http://s3.bite-fight.us/c.php?uid=181043
walleeme is offline   Reply With Quote
Armada-to-Titan Spoiler Mod Redux: Step-by-Step W/Photos markinho Titan Parts & Accessories 50 12-11-2008 05:52 AM
radiator removal? deedking Titan FAQ & Howto Area 5 08-25-2007 02:25 PM
Got my new NADA Step Bars installed!!! **PICS** SeanVree Titan Parts & Accessories 3 06-15-2006 01:14 PM
Step 1 Wash, Step 2 Clay Bar, Step 3...it got dark jpup Titan General Discussion 9 05-09-2005 12:41 AM
Heres pics of step bars and tonneau cover beano Titan Interior Discussion 5 07-30-2004 02:11 PM
