Old 02-12-2009, 09:29 AM   #1 (permalink)
HT: Make your DDM 880 Fog Light HID kit Truely PnP
Introduction:
So, I got my HID kits from DDM. But, The fog light kit didn't really come with a connector to connect it to the factory fog light plug. but, instead it just came with pins that would plug into the connector. Well, I didn't really like this. It's not water tight. You could wrap it with tape, but, that's pretty crappy too. So, I fixed it.
***** Difficulty is a 2/5, requires soldering************
Tools Required:
Soldering Iron
Wire stripper
Wire Cutter
Heat gun or lighter
hot glue gun
Multi Meter
Material required:
Hot Glue
Solder
Heat Shrink
old halogen fog light bulb
1: First of all. Here is the lousy spade connector with no housing that came on the kit. Cut this off and strip the wire.
2: take the old halogen bulb and cut the actual bulb off the connector.
3: Put a piece of heat shrink on the wire for later and then solder the wire to the left over metal on the connector. In this picture you can see which side the red wire goes on. I USED A MULTIMETER TO CHECK THE POLARITY ON MY TRUCK. PLEASE CHECK IT ON YOUR TRUCK AS IT MAY BE DIFFERENT.
4: Slide the piece of heat shrink over the soldered pin and shrink it. I used a heat gun but a lighter will work fine.
5: Use a hot glue gun to fill the cavity in the connector with hot glue to make sure everything is nice and water tight.
ht-make-your-ddm-880-fog-light-hid-kit-truely-pnp-pin.jpg  ht-make-your-ddm-880-fog-light-hid-kit-truely-pnp-clip.jpg  ht-make-your-ddm-880-fog-light-hid-kit-truely-pnp-solder.jpg  ht-make-your-ddm-880-fog-light-hid-kit-truely-pnp-shrink.jpg  ht-make-your-ddm-880-fog-light-hid-kit-truely-pnp-glue.jpg
SethMan408 is offline   Reply With Quote
Old 02-12-2009, 09:30 AM   #2 (permalink)
Re: HT: Make your DDM 880 Fog Light HID kit Truely PnP
6: The finished product!
Old 02-12-2009, 02:00 PM   #3 (permalink)
gary748's Avatar
Very clean and factory looking, I'm all about plug and play. Nice job Seth!!!
IRC VK56 PIT CREW CHEIF
2005 Silver SE 4X2 KC
Performance: Uprev Tuned, Injen CAI (Wrinkle Black Powder coated), '07 Intake Manifold, Nismo Exhaust,
TrueTrac, Mag-Hytec
Suspension: Stillen Rear Sway Bar, PRG Shackles
Wheels: 22" Foose DF-6(Black), Yokohama Prada-X tires
Exterior: Armada Front Air Dam, Catz 6k HIDS, DDM 6k fogs
Audio: JL Audio, Alpine
gary748 is offline   Reply With Quote
Old 02-13-2009, 10:35 AM   #4 (permalink)
pinoytitan's Avatar
pretty sweet. im glad someone knows how to wire things up. i hate wires. LOL but this looks really simple.
2005 Blizzard White Nissan Titan IRC CREW MEMBER International Racing Club VK56
Performance: AEM Tube with K&N Filter, PROJECT GIANT MOUTH, 2008 Titan Plenum, Thrust_Titan Thermostat, Thrust_titan ThrottleBody Intercooler, Nismo Headers, Nismo Catback True Dual Exhaust, UPREV Tuned
Interior: (2) RE 10inch subs, 600.1 JBL Amp, and Tech12volts box
Exterior: Klasse AIO Wax, OEM painted wheels wrapped in sucky Falken Ziex. Nismo Sticker
pinoytitan is offline   Reply With Quote
Old 10-30-2009, 05:43 PM   #5 (permalink)
gweasel77's Avatar
So, the DDM fog kit's don't come w/ a plug? I'm doing this mod if they don't!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
Custom 4" Ram Air / Fujita Intake w/ DEI Heat Shielded Box / AirRaid TBS / TB Screen Removed / TB Coolant Bypass / '08 Intake Manifold / Trans. Cooler / Nismo LT Header's / Banks Monster Exhaust / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding System / Burn-Out Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior:
Ruff Racing R286 22"x9.5" Chrome's w/ 305/45/R22 Nexen Roadian HP's / Stillen Diff. Cover / Traction Springs / DDM 8K HID's / Armada Air Dam / SolarGard Tint / Tow Hook's / Debadged
Fog Light's w/ HID's Next
waiting on ST Shackles
gweasel77 is offline   Reply With Quote
Which DDM HID kit is the one I want. Confused. Footloose301 Titan Performance Modifications 19 02-24-2009 12:36 AM
F/S HID Fog Light Kit 3000K jaho1979 Buy/Sell 0 03-16-2008 09:15 PM
Brand New H8 HID Fog light kit... titaning Buy/Sell 1 04-13-2007 08:18 AM
HID Fog Light Dielectric Lab Titan Parts & Accessories 17 01-07-2007 11:15 PM
