Old 07-08-2009, 11:11 PM   #1 (permalink)
Sal Monsta's Avatar
Ignition stuck
So i went to turn my truck off today and the ignition wont move into lock position. The truck is in park but the key still wont go to lock and come out. WTF
Sal Monsta is offline   Reply With Quote
Old 07-08-2009, 11:28 PM   #2 (permalink)
HRTKD's Avatar
Re: Ignition stuck
Maybe try rotating the steering wheel.
Jim
Old 07-08-2009, 11:44 PM   #3 (permalink)
Sal Monsta's Avatar
Re: Ignition stuck
Yup tried that.
Old 07-09-2009, 05:13 AM   #4 (permalink)
mjw357's Avatar
Re: Ignition stuck
Turn the truck back on (don't have to start it) hold brake pedal, move trans lever out of park, back into park, turn truck off.
Mine sticks like that sometimes if I don't get it all the way into park before I turn the key off.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 07-09-2009, 05:16 AM   #5 (permalink)
Quartz's Avatar
Re: Ignition stuck
Make sure the shift lever is all the way over to the left when you put it in park. My Titan does the same thing.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 07-09-2009, 07:23 AM   #6 (permalink)
Sal Monsta's Avatar
Re: Ignition stuck
Tired all those things. Tried every little trick i can think of. Moving the steering wheel back and forth, moving it to one side.
Im just gonna drive it back to the dealership and have them figure it out.
Old 07-09-2009, 03:49 PM   #7 (permalink)
Sal Monsta's Avatar
Re: Ignition stuck
Thanks for the seggustions. Took it into the dealership and it ends up that something had jammed up in the steering column causing the ignition to not recognize the that the shifter was in the park position.
Ignition Locked Up Havey81 Titan FAQ & Howto Area 12 05-15-2009 07:41 AM
Key stuck in the ignition after parking UltraTitan Titan General Discussion 3 02-03-2009 06:46 PM
Serious Ignition Problem Please Help!!! bodydropped72 Titan General Discussion 19 04-19-2008 06:11 AM
Can't turn the ignition switch. NewTruckGuy22 Titan General Discussion 7 07-12-2005 08:55 AM
ignition won't turn royjratc Titan Problems & Dealer Service 6 01-25-2005 08:23 PM
