cleaning windshield washer fluid nozzle - Nissan Titan Forum
#1 (permalink) Old 07-08-2009, 10:42 PM
albonismo's Avatar
iTrader Score: 3 reviews
one of my nozzles is not working, 99% sure its clogged with wax or something. tried scrubbing the hole a little to clear it but to no avail. how do you pop off the head to get a better look at it? thanks
'06 Smoke XE CC FFV
Mods: AEM Intake, Stillen Dual Rear Exhaust, 2° Timing, 8k HIDs, 2" Leveling, Deaver C-30 pack, rear Bilsteins, PRG DCBB, 18x8.5 AR Marins, BFG AT KO 305/65r18, Custom Grill, color-matched rear bumper, smoked tail lights, debadged I need new pictures
"Taste the rainbow." -Shakespeare
Loading Swag...
████████████████ 100%
Complete.
albonismo is offline
The Following User Says Thank You to albonismo For This Useful Post:
gcole (07-14-2009)
Advertisement
#2 (permalink) Old 07-09-2009, 12:41 AM
OneQuick06's Avatar
iTrader Score: 4 reviews
Re: cleaning windshield washer fluid nozzle
You could try running a long, thin needle in the nozzle to break up the clog. If that doesn't clear it, then you may have to get into the line that runs the fluid.
There's always room for beer
2006 Galaxy KC BT SE
Mods: Click here Pics: Click here
CrayolaWhore™
MonkeyPumperWhore™
OneQuick06 is offline
#3 (permalink) Old 07-13-2009, 08:50 PM
albonismo's Avatar
bump, any ideas?
'06 Smoke XE CC FFV
Loading Swag...
Complete.
#4 (permalink) Old 07-13-2009, 09:01 PM
OneQuick06's Avatar
Did you try my idea?
CrayolaWhore™
MonkeyPumperWhore™
#5 (permalink) Old 07-13-2009, 09:05 PM
rjspitz's Avatar
iTrader Score: 0 reviews
Maybe let some vinegar soak on it?
Or try OneQuick's idea and use a needle. It's worked on past cars for me... You can usually re-aim the nozzle with a needle too.
rjspitz is offline
#6 (permalink) Old 07-13-2009, 09:34 PM
albonismo's Avatar
yup, but with no luck. i guess the next step is to pop it off and take a closer look.
'06 Smoke XE CC FFV
Loading Swag...
Complete.
#7 (permalink) Old 07-13-2009, 10:56 PM
OneQuick06's Avatar
Yea, in that case. You may have pluggage in somewhere in the tubing itself.
CrayolaWhore™
MonkeyPumperWhore™
#8 (permalink) Old 07-14-2009, 03:21 PM
OneQuick06's Avatar
Any luck on this? I'm curious as to how this works out, for future reference.
CrayolaWhore™
MonkeyPumperWhore™
#9 (permalink) Old 07-14-2009, 09:14 PM
remove the fluid line from the nozzle and determine if the blockage is at the nozzle or somewhere upstream of the nozzle.
SpeedFreak is offline
#10 (permalink) Old 06-09-2011, 01:09 PM
I had the same problem I popped the tube off and used a can of dust off and blew it through the line... worked perfect the second time...(first time i blew it towards the windshield and the clog had no where to go.
Moungo is offline
#11 (permalink) Old 06-09-2011, 01:41 PM
beason's Avatar
iTrader Score: 10 reviews
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
you have to pop off the cowl on that side to get the nozzle off. you can probably just remove the retainer under the hood corner, and then remove the ones along the seal under the hood, and tilt up the cowl enough to get to the bottom of the nozzle. I would just undo the hose first and have someone hit the washer button to see if anything comes out. if it does you know its the nozzle. you should be able to pinch the clips and pop it out.
Ever growing mod list here
WhinyWhore™
beason is offline
Jump to top
Linear Mode Linear Mode
Washer Fluid Reservoir geelo1 Titan Parts & Accessories 15 05-23-2008 10:25 AM
Washer Fluid Light On ajeaton Titan Problems & Dealer Service 1 12-07-2007 08:45 PM
Windshield Washer Fluid Leaking skromfols Titan Problems & Dealer Service 7 07-27-2006 01:32 PM
Heated Washer Fluid silvernik25 Titan Parts & Accessories 3 03-23-2006 05:54 AM
Windshield Washer/De-icer ruauman2 Titan General Discussion 9 12-01-2004 06:14 AM
