TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-19-2009, 08:50 AM   #1 (permalink)
troyrod91's Avatar
Question flex fuel octane in the 90's?
i have a 2008 flex fuel and i was reading the manual and it only says use E85. but i know theres has to be a way to use a higher octane. does anyone know anything about this?
troyrod91 is offline   Reply With Quote
Advertisement
Old 11-19-2009, 08:54 AM   #2 (permalink)
Re: flex fuel octane in the 90's?
E85 is around 105 octane. 85 is the percent of alcohol in the fuel. You will get better mileage from the regular fuels out there.
huffhuff is offline   Reply With Quote
Old 11-19-2009, 09:03 AM   #3 (permalink)
Yahooligan's Avatar
The octane is actually quite a bit less than 105. Think of it more as a super super unleaded, not as a racing fuel.
Octane: A minimum octane for E85 is not specified. FFV’s
can tolerate the lower octane of gasoline i.e. 87 (R+M)/2.
There is no requirement to post octane on an E85 dispenser.
If a retailer chooses to post octane, they should be aware that
the often cited 105 octane is incorrect. This number was
derived by using ethanol’s blending octane value in gasoline.
This is not the proper way to calculate the octane of E85.
Ethanol’s true octane value should be used to calculate E85’s
octane value. This results in an octane range of 94-96 (R+M)/
2. These calculations have been confirmed by actual octane
engine tests.
The dog: 2005 Titan SE CC BT 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, RAS, SnugTop Sport shell, 5000k HIDs - FOR SALE
The old fish: 1984 Scarab 21SS - Marine Power 454 - SOLD
The new fish: 1998 Seaswirl 170 BR I/O
Yahooligan is online now   Reply With Quote
Old 11-19-2009, 09:24 AM   #4 (permalink)
sudden urge's Avatar
E85 has an octane rating ranging from 100-105, making it a high performance fuel.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Superchips, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Best FST 1/4 mile time of 14.632 running Bully Dog 87 tune+2.
Old 11-19-2009, 10:33 AM   #5 (permalink)
troyrod91's Avatar
i was just thinking about running a premium gas (from the pump) but i have flex fuel so idk how that would work? i think the premium is either 91 or 93.
Old 11-19-2009, 10:47 AM   #6 (permalink)
desertruner09's Avatar
Flex fuel vehicles mean that they are capable of running E85, not that you only have to use E85. So you can put 87,89 or 91 (or whatever you have where your at) and you'll be good to go.
2006 Titan 2wd CC SE Granite w/Big Tow with 98K miles
DIY Airbox mod with drop in AMSOIL Absolute Efficiency Air Filter and a DIY true CAI //// Stillen Sport Rotors with Hawk HPS Pads //// Goodridge SS Brakelines //// Active Tuning Grounding Kit //// PRG Shackles //// PML Differential Cover with Mag-Hytec gasket //// Armada Air Dam //// Headlight Mod (black) //// Bilstein 5100's on middle setting and PRG 1.5" spacer //// PRG Traction Bars //// Air Lift Ride Control Air Bags //// PRG Sway Bar End Links //// Bully Dog GT 87 +2 tune without WOT restriction ////
desertruner09 is offline   Reply With Quote
Old 11-19-2009, 10:49 AM   #7 (permalink)
troyrod91's Avatar
ok thanks for the help
Flex Fuel 900King Titan General Discussion 43 05-27-2010 02:31 PM
Flex fuel VS reg fuel engine surfintitan68 Titan Engine, Transmission & Drivetrain 8 10-16-2009 08:30 AM
Flex Fuel? Country_Boy2493 Titan General Discussion 4 10-29-2008 09:23 PM
Flex Fuel E85 9sec95autoTT Titan General Discussion 16 11-28-2007 08:35 AM
Any of you Titan owners have the Flex Fuel option and running E85 fuel??? kickinasphalt Titan General Discussion 16 12-03-2005 05:00 PM
