Re: Help with Tow Hitch Wiring
When my cap was installed they pulled power from within the tail light housing. It's a shorter run and no guessing as to which wire to use. In case you haven't already found it, there is a hole within the tail light cavity to get to the bed. That's a handy spot to run the wires up to the cap. Otherwise, I have no idea which wire is which at the trailer connection.
Jim
