What The Heck?? Radiator Hose Collapsed(HELP) - Nissan Titan Forum
post #1 of 22 (permalink) Old 12-12-2009, 03:53 PM Thread Starter
iTrader Score: 0 reviews
Got 06 CC,OR,BT,FF,4x4,just over 30k.Every thing running and acting normal. I had a oil change about 700 miles ago. Checked the oil level today and noticed the darn top radiator hose sucked closed. All levels of fluid are fine so I opened the reservoir cap and seemed to release the vacuum?? The temps here are dropping into the mid to high 20's and reaching right at 40 for the highs?? The only search result said could be radiator cap or reservoir cap? Dose any one know for sure which it is and also should the hose be replaced along with the faulty cap??? Thanks for any HELP!!
curbfinder is offline
Advertisement
post #2 of 22 (permalink) Old 12-12-2009, 04:14 PM
sudden urge's Avatar
iTrader Score: 4 reviews
Re: What The Heck?? Radiator Hose Collapsed(HELP)
That's normal, don't worry about it. However, I never caught mine doing that, but many others had your same experience.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is offline
post #3 of 22 (permalink) Old 12-12-2009, 04:18 PM
R3DN1CK's Avatar
http://www.youtube.com/watch?v=2WJVHtF8GwI
2006 Nissan Frontier D40 CC LE 4.0 2WD
R3DN1CK is offline
post #4 of 22 (permalink) Old 12-12-2009, 04:34 PM
twistedfreedom's Avatar
iTrader Score: 9 reviews
Send a message via AIM to twistedfreedom
I'm has done it too took it to the dealer. they said it's normal it's never over heated so I'm going to not worry about it
2008 Toyota Tacoma The Incredibuild
Farewell titan you will be missed, your MPG will not
PINKBARBIEWHORE™
Removed due to complaint
twistedfreedom is offline
post #5 of 22 (permalink) Old 12-12-2009, 04:42 PM
R3DN1CK's Avatar
Pressure varies with temp or altitude, your truck was probally warm when the coolant was filled and not opened since then, now it's cold outside and the molecules contracted.
R3DN1CK is offline
post #6 of 22 (permalink) Old 12-12-2009, 05:09 PM Thread Starter
All true, I freshened up the reservoir this summer with some new coolant.
post #7 of 22 (permalink) Old 12-12-2009, 05:32 PM
AZPRO4X's Avatar
iTrader Score: 8 reviews
Mine does it to i really never worried about it because as soon as it warms up its gone...
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
post #8 of 22 (permalink) Old 12-13-2009, 05:30 AM Thread Starter
Does any one know what causes this? Never owned a vehicle that acted like this. So is this truly nothing to address or be concerned about. It's a real shocker for the first time??
post #9 of 22 (permalink) Old 12-13-2009, 06:14 AM
TitanBlue's Avatar
iTrader Score: 3 reviews
It would be helpful to see the diagram that has been posted before, that shows the routing of the coolant system. It is pretty sophisticated, remember that the overflow bottle is really a continuous flow bottle, and is pressurized just as the radiator is. I would suspect the thermostat is not allowing a small bypass of coolant as it could. But that feature is not on all vehicles, so just a wild thought, not a true diagnosis. We had a Pony motor doing the same at work, all I recall is we replaced the hose, nothing more.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
post #10 of 22 (permalink) Old 12-13-2009, 10:02 AM
Yahooligan's Avatar
It's caused by physics. The engine heats the coolant, the pressure increases (sometimes the cap will vent excessive pressure), you park the truck and the coolant contracts as is cools. This causes a vacuum and the upper radiator hose is sucked in. Nothing to be worried about, it's normal for the Titan.
The new pup: 2007.5 Dodge Ram 3500 MegaCab SLT 4x4 SRW, Inferno Red
The old dog: 2005 Titan SE CC BT 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, RAS, SnugTop Sport shell, 5000k HIDs - SOLD!
The old fish: 1984 Scarab 21SS - Marine Power 454 - SOLD
The new fish: 1998 Seaswirl 170 BR I/O
Yahooligan is offline
post #11 of 22 (permalink) Old 12-13-2009, 11:03 AM Thread Starter
Thanks for the HELP/input !! I wasn't overly concerned because the gauges and fluid levels are normal. I guess all TITAN's do this at one time or another. Seeing it for the first time is a surprise I could definitely live without.
post #12 of 22 (permalink) Old 12-13-2009, 11:56 PM
R3DN1CK's Avatar
important question... when it does heat up does the hose return to form?
R3DN1CK is offline
post #13 of 22 (permalink) Old 12-14-2009, 04:49 AM
Blackbeauty's Avatar
iTrader Score: 12 reviews
Yes.... Mine did this when I was changing my oil the last time... Freaked me out a bit, as I had never seen this on any prior vehicles either... Shut it down, opened the radiator cap, it went back to normal... What gave me reason to NOT worry was that the discoloration on the outside of the hose indicated that this was not the first time it had done it... I just never noticed it before...
But it will go back to open on its own...
Blackbeauty is offline
post #14 of 22 (permalink) Old 12-14-2009, 05:48 AM
honeykeeper's Avatar
iTrader Score: 1 reviews
Send a message via Yahoo to honeykeeper
Both the upper and lower radiator hoses collapse and return to "NORMAL".
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with 08 Big Tow-E-Loc, Blizzard Graphite/Titanium Interior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-4th set, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades-2nd set, Optima Red Top battery.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
JFK http://www.youtube.com/watch?v=J8dLHZ6jKFc
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=KG5zckBejK0
honeykeeper is offline
post #15 of 22 (permalink) Old 12-14-2009, 01:54 PM
R3DN1CK's Avatar
guess it's a cold weather thing? just have to make sure you have the proper coolant mixture.
R3DN1CK is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Cracked radiator? Broken hose? What is it? 06_SMOKE_SE_CC Titan General Discussion 38 05-18-2009 10:53 PM
Radiator Hose DezertTitan Titan Engine, Transmission & Drivetrain 4 11-24-2008 03:06 PM
collapsed upper radiator hose?? [SC]Titan Titan Problems & Dealer Service 31 01-04-2008 07:30 PM
Radiator Hose collapsed!!! Shane06fl Titan Engine, Transmission & Drivetrain 4 10-16-2006 07:24 PM
Radiator hose deformed? mbjkiller Titan General Discussion 14 05-03-2005 02:15 AM
You may post new threads
You may post replies
