Originally Posted by steve
I certainly will attempt to find those covered ATM's. If you read the thread I need that window cracked due to a bodily function problem and a bad habit. Rain guards should do the trick. Still concerned of the occaision that water will fill up the window, lock and mirror controls. Not losing sleep here, just seeing if anyone else have thought about how much water those switches will tolerate. Maybe someone has taken the panel apart to see if this is even an issue.
Yes, take them apart, coat the switch contacts with silicone dielectric grease, and then paint them with liquid electrical tape.
