Hey guys. I'm going to be towing my buddy's fishing boat over the break. It's between 18-22 feet but I don't know the wait. Is it okay to run my truck on Light Tow with this load or should I just go back to stock to be safe. Also, proper procedure for towing is in 4 (instead of D) with tow mode ON, correct?
Thanks fellas
__________________ ESCORT SOLO S2 RADAR DETECTOR FOR SALE!!!
2008 PRO-4X Black on Black 4x4 w/ Leather package, Big Tow, and Utility Bed BlackJack
Mods: Performance: Superchips FlashPaq - 93 tune w/ 2* timing advance, 18" Magnaflow Muffler Suspension: PRG 1.5" Leveling Kit Wheels & Tires: 20x9 Ballistic Offroad Jesters, 33x12.50x20 Toyo Open Country M/T Audio: Kenwood Excelon DDX812 with Kenwood KNA-G510 Navigation Module, 2 12" RE Audio SE's, Sundown SAE-1000D amp, Tech12Volt Sealed Box Accessories: 6000K McCulloch HID Lows, 6000K DDM Tuning HID Fogs, 20% front tint, 5% in the back, and 5% on top of windshield, Hardwired Valentine 1, RBP 4.5" Black Exhaust Tip
I would guess the weight would be 3500#-4500#, so I really wouldn't worry too much. Yes, you are correct about the gear selection, although on flat highway with a lighter trailer like that you could get away with using D without problems.
__________________ - 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
The Following User Says Thank You to mjw357 For This Useful Post:
Man i used the the light tow tune when I was hauling 8 people around and man was I suprised! I was pulling away from my friend in her scion tc up hills.
///SIG IMAGE TOO LARGE, RESIZE TO 300x200 or smaller\\\
Thanks fellas
Definately use the Tow Mode. Thats exactly what it was designed for. I haven't personally used mine but i have read others saying it made a difference. Let us know how it worked.
__________________ The views expressed in this post are my honest opinions. Anybody not liking my views can just get over it already.
2004 LE CC 4x4 BT Deep Water
Bilstein 5100's all (4) corners
EBC 7000 Series Green Stuff Pads
EBC Slotted & Dimpled Rotors
SS Brake lines
ATE Super Blue Dot 4 Brake Fluid
Optima Yellow Top Battery
K&N CAI
Superchips Cortex
Flowmaster Muffler w/dual outs
Magnaflow SS Exhaust Tips
DDM 35W 6000K HID's lows/highs
(2) Hella 100W Off-Road lights
Firestone Destination A/T
You're referring to the Tow Mode button, correct? I know to use that. I always use Tow Mode when I'm pulling something, but I was just curious because I haven't had the Superchips tune. I just wanted to make sure that the weight of the boat wouldn't be too much for the Light Tow tune.
Thanks
leave it in D and use tow mode, i've towed my race car with zero issues for hundreds of miles
The War Machine
Canteen Green
4x4 Offroad Big Tow Fosgate Packages
Nitto Terra Grapplers / oem brush guard / xe handles / slotted and drilled rotors from rotorsonline.com
Superchips Cortex
my toy: 2004 turbo LS1 GTO
But is the boat light enough to tow with the Light Tow tune or should I run it stock?
I was referring to the Towing Tune on your Superchips. If you have a Titan with the tow mode switch use it too and tow out of OD. If the boat ends up feeling really light try OD. You should be able to tell if its dogging too much in OverDrive.
SS Brake lines
K&N CAI
Superchips Cortex
...Run the Tow Program, it will work fine towing anything...
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
Thanks
Dude when superchips means light tow they mean 11,000 lb lol
I would only use tow mode if your in hills and involving alot of gear changes. But if you are going on flat terrain.....aka the desert, D is just fine. Big-tow gears allow you to be in high gear without shifting down once your up to speed. The tow haul mode button just holds gears longer. Selecting 4th gear for the whole trip would be over kill seeing that your 5th gear in the BT package is the equivalent to a 4th gear.
__________________ "Chase the Dream....not the Competition."L.A. County EMT
