Evaporative Emission System leak Detected, (Large leak) - Nissan Titan Forum
post #1 of 12 (permalink) Old 03-21-2010, 06:12 AM Thread Starter
iTrader Score: 0 reviews
p0455 is the code.
i was driving this morning and the check engine like came on, checked the code with my bully dog and thats what it said.
did a quick search on goggle, so i already checked the gas cap. anyone know what this could be ? i seem to have problems with my Titan nobody else has yet went through.. lol
Owner Of A White 2007 Nissan Titan King Cab,
www.topchoicedecals.com Decals And Custom Decals works part time at www.guysafterconception.com
jessestylex is offline
Advertisement
post #2 of 12 (permalink) Old 03-21-2010, 06:24 AM
iTrader Score: 4 reviews
Re: Evaporative Emission System leak Detected, (Large leak)
Maybe the Evap Vent valve.
http://www.titantalk.com/forums/atta...ap-control.pdf
http://www.titantalk.com/forums/atta...ntb06-095b.pdf
bestatchess is offline
post #3 of 12 (permalink) Old 03-21-2010, 07:02 AM Thread Starter
thanks for the link, ill check it out after the rain stops.
looks like most of the stuff is fairly easy to get to. i hope it's just a bad hose or bad gas cap.
post #4 of 12 (permalink) Old 03-21-2010, 08:04 AM
Learjet's Avatar
after you get that vent valve cleaned or replaced, you can get this to prevent it from happening again
EVAP-SERVI :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
SOLD, after 122,000 great miles:
2006 SE, CC, Big Tow, white
Born 5/06
Timbrens added
Learjet is offline
post #5 of 12 (permalink) Old 03-21-2010, 08:05 AM
chieflikalotapus's Avatar
iTrader Score: 9 reviews
Sounds like it's the evap valve that bestatchess was talking about if it's not that then maybe a tear in the hose line somewhere that's causeing it to leak
The Road Warriors On and Off
chieflikalotapus is offline
post #6 of 12 (permalink) Old 03-21-2010, 09:56 AM Thread Starter
the valve can be cleaned? with what?
post #7 of 12 (permalink) Old 03-21-2010, 01:35 PM
Learjet's Avatar
WD40, Brake cleaner etc. Some have had sucess cleaning it, might have to apply voltage to operate it while spraying cleaner thru it. Do a search and you might find more info about how other tried to clean it. The problem is no filters on the early models which allows trash to get in and not allow the valve to seal properly.
Born 5/06
Timbrens added
Learjet is offline
post #8 of 12 (permalink) Old 04-04-2010, 06:46 PM
I'mRonBurgundy?'s Avatar
iTrader Score: 1 reviews
I had the same problem and after 4 trips to the dealer (the last one with me bringing a copy of the TSB from Nissan) they finally repalced the vent control valve and magically the light has not come back on. Sucks when a dealer seems to be ignorant to their own TSBs.
I'mRonBurgundy? is offline
post #9 of 12 (permalink) Old 04-05-2010, 08:40 AM
I've had the same issue for several months now. I replaced the gas cap but that didn't fix the problem. I then purchased the vent valve and finally installed it (pretty easy to do, just couldn't find the time). I then cleared the code and after driving a couple hundred miles, the SES light came back on. Could there be another reason that I am having this issue?
Also, when I was under the truck changing the valve, I noticed that there was a lot of oil all over the undercarriage in the vicinity, but the rest of the undercarriage was clean. I checked the rear end and it appears to be clean also so I don't think its gear oil. Could this be related to the valve?
ssusca is offline
post #10 of 12 (permalink) Old 07-06-2011, 05:55 AM
Well, I read in these forums all the time but I usually never post. I had the same problem so I replaced the gas cap. Problem solved...for about 2 weeks. Replaced the vent valve. Problem solved...for about 2 days! My new code is similar but its says my evap vent itself is bad. Probably needs to be cleaned. I post a tutorial on how to do it when I have time.
riveter77 is offline
post #11 of 12 (permalink) Old 07-06-2011, 08:08 PM
butterbean's Avatar
If you decide to replace the evap vent control valve, check out Rockauto.com. They have the part for about $40. I replaced mine a couple of months ago and have had no problems since.
butterbean is offline
post #12 of 12 (permalink) Old 07-13-2011, 06:42 PM
mud chicken's Avatar
Having the same problem. Light came on stopped at autozone tells me its a large evap leak. Replace gas cap about 100 miles later light comes back on. I want to rescan to see what the code is calling but this light is driving me nuts!! I guess my next move is the valve and just keep my fingers crossed that it will solve my problem. From what I have read it seems to be hit and miss. I have read a bunch of guys spending over $500 to replace everything to finally fix the problem. Gotta love that I just get the truck and about 200 miles this starts.
Black 04 Crew Cab 4x4 - 6" Rough Country Lift - AFE CAI - TB Spacer - JBA EVOL Cat Back - Full Tint
mud chicken is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
EVAP Large Leak mcclintock89 Titan Engine, Transmission & Drivetrain 54 04-29-2015 06:34 AM
"Large EVAP Leak" code ArtechnikA Titan Problems & Dealer Service 14 10-14-2009 03:28 AM
large evap leak ? ineedabin2 Titan Engine, Transmission & Drivetrain 2 09-08-2009 08:53 AM
Exhaust Leak & Transfer Case Leak Clinsta Titan Problems & Dealer Service 1 01-29-2007 11:27 AM
Leak? crippeninc Titan Engine, Transmission & Drivetrain 6 01-18-2007 08:48 PM
You may post new threads
You may post replies
