Originally Posted by bluesun
I have never had 4 wd but I can't believe that this is normal. Today it was raining heavy so I switched to 4 HI. Everything works great, but when I'm in a parking lot and the wheel is turned, it's like the parking break is on. The truck just grinds and requires heavy throttle to even get moving.
This isn't normal for 4wd is it? Any ideas?
Odds are that's totally normal. The Titan has old fashioned, wheel locking, 4WD. If you're in a parking lot, a place that requires tight turns, you're experiencing simple physics. Your outside tires want to turn faster than your inside tires during the turn due to the smaller radius required on the inside tires. This will cause your wheels to skip or hop, on dry pavement can even dig a chunk of rubber out of your tires. Turn your 4WD off in a wet parking lot.
We do not have "all wheel drive" or the sort. That system has a center differential with a viscous slip coupler that allows the wheels to turn at different rates. Our 4WD is made for low traction conditions...ice, snow, sand, mud, etc. Save 4WD for these conditions.
