Originally Posted by piopremier
I bought a new terminal with 1 1/0 guage 2 8 guage and a 4 guage input. I was thinking of running my new wire to the 1/0 guage input and then running a 4 guage wire from that nut your talking about to the 4 guage input. Think that would be ok?
Is it like the Directed Audio 62155 Battery Terminal Kit shown here:
http://www.carmedia1.com/en-us/dept_225.html ??
Are you saying that you can't get the + terminal (like the Directed Audio Terminal) on the + terminal of the battery because of the stock fuse attachment?
If that is the case, I would not just suspend the Directed Audio style terminal, but rather use a distribution block like one of the AudioPipe blocks shown here:
https://www.expeditionexchange.com/a.../indexmain.htm
or here:
http://www.exploretheuniverse.net/99...on%20Block.htm
In any case, the thickest wire should go to the battery (0 gauge or whatever), because that leg will carry the most current.
Then you would need to make sure the wire sizes were adequate for the loads (total for the wire to the battery and also in each leg).
Here is a site with a nice voltage drop and wire gauge calculator:
http://www.powerstream.com/Wire_Size.htm
You would also want to provide appropriate fuses. You can find all sorts of stuff like this by searching for "AudioPipe" on Ebay.
