Originally Posted by BudmanHemi
I found out your rotors come from where ours do. We also have the same problem. We are getting new calipers, and pads. Also turning down rotors, and in some cases replacement. For those with warpage you should be getting new calipers, pad's soon. Mine have been on back order for a month.. When i asked why they told me because the company that provides them does nissan, dodge, and many other manufacturers, and they cant keep up.. Just letting you know..
Hey, Budman...
I had a 1/2 ton Dodge and had similar problems; I was able to cure mine by using an old-fashioned mechanic's trick. Sometimes the heat built up on the pads gets re-transferred to the rotors when you're sitting still after a long hard stop, and can cause glaze spots or minor warp problems. This following method only works if the rotors are showing small warps, or inconsistent braking effort. For big problems, they have to be machined or replaced.
Here's how I successfully dealt with it: When I did have a (slightly) warped rotor, or rotors with glazed spots, I gave the truck a really hard stop. Then instead of just sitting where I stopped, if at all possible I release the pedal and let the truck roll a little, even though I still had my foot on the brake. This allows the heat to be evenly distributed over the rotors, and allows them to cool more evenly, hopefully bringing them back into line a bit.
As a preventative measure, when stopping hard from higher speed, stop a little short, and allow the truck to roll forward slowly, (even though you still have your foot on the brake) thus allowing the brakes to cool evenly, without a big hot spot from the pads.
I had a lot of trouble with my Ram's brakes (and my Dakota's before that) until I started doing this as a habit.
This may and may not help, but it is certainly something to try.
Steamguy
