Wheel Bearing Failure? - Nissan Titan Forum
post #1 of 7 (permalink) Old 06-22-2010, 05:08 AM Thread Starter
pdk9's Avatar
iTrader Score: 0 reviews
Does this sound like a bearing is failing? 2004 KC 4x4 with 76,000 miles w/stock tires and rims with even wear on all tires. At all speeds I get a humming noise that sounds the same as if you are in 4high on pavement (definitely not in 4x4), when I turn left the noise is reduced. There is no play in the wheel at all, only the noise. I jacked it up, put in 4high and ran the rpm's to 2000 then listened to both hubs with a stethoscope. The passenger front is quite but the driver front has a definitely noise coming from it.
I took it to a dealer who said the bearings are fine because there is no play in the wheel. I am now being told by another mechanic that the "cartridge" type bearing wont wobble until the last couple hundred miles, then it fails. He also said the noise is what you will notice in the beginning of the bearing starting to fail. The non-dealer mechanic is saying that if the dealer is only trying to "wobble" the wheel to test the bearing then it will appear fine because it isn't to that point yet, but when it does wobble it will fail fast. Does this make any sense??? Not sure if I should change the hub assembly or not.
pdk9 is offline
Advertisement
post #2 of 7 (permalink) Old 06-22-2010, 05:22 AM
Nightstalker 6's Avatar
Re: Wheel Bearing Failure?
Yup, the races and or rollers are starting to get flat spots on them. its a fairly quick and easy job to replace them.
The very existence of flamethowers proves that sometime, somewhere, someone said to themselves: "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done."
2006 Galaxy Black CC 4X2, PRG 2.5/1.0 mini lift, Bilstein 5100 struts on front and 5100 shocks on rear, headlight mod, airbox mod, BDGT, Axle Vent Mod, VHT Tails & 3rd Brakelight, GPS Speed Sensor Mod, Royal Purple Oil, Tranny Fluid, Power Steering Fluid, and Purple Ice in the Dual Core All Aluminum CST Radiator.
Nightstalker 6 is offline
post #3 of 7 (permalink) Old 06-22-2010, 05:24 AM Thread Starter
pdk9's Avatar
Thanks for the reply, do I have to change the entire hub assembly?
pdk9 is offline
post #4 of 7 (permalink) Old 06-22-2010, 06:17 AM
gusman's Avatar
yessir thats your bearings, be ready to replace the pass side soon too they usually go around the same time... I believ the bearings are indeed part of the hub? But that's an educated guess don't quote me on it
'13 Ram 1500 Sport Quad Cab 4x4 Black on Black
'08 Cummins 2500 QC SWB H&S DeletedSOLD!!!!!
'05 Galaxy LE KC 4x4 BT SOLD!!!!! But Im Still Lurking
MBRP 3.5" Cat Back Single Side Exit, 4" Poilshed Tip (Painted Black) ::PRG Minilift (2"/1.5")
::325/60 18 nitto tg's:: Nav Bezel with Magellan 1700::18X9 XD Monsters 5.71"BS, 18mm Offset::Toyota Tundra mirror lights custom mounted on BT mirrors:: 2* Timing Advance
Padre's T
-2010 Galaxy LE CC 4X4 BT
gusman is offline
post #5 of 7 (permalink) Old 06-22-2010, 10:52 AM
yep it's sold as one unit and it's 138.00 per wheel hope this helps.
Montrose
08.5 Titan Pro4x gray CC, Nismo CAI and cat back, hypetech beta unit 002,stillen front and rear swat bars, PRG shackles, PRG motor mounts, PRG Trans mount.
2013 Challenger 392 SRT8 Plum Crazy Purple Auto Transmission, fully loaded. Mods Arrington CAI, 87mm TB, Mopar strut brace, Diablo tuner, MBRP 3" dual cat back, BT catch can.
Montrose
MJB09SRT8 is offline
post #6 of 7 (permalink) Old 06-23-2010, 04:21 AM
normally. you wouldn't have to change the whole front "cartrige". wheel bearing races are made of a hardened steel and ground down to a near perfect finish, as are the roller bearings. Historically, you would pound out the old races and bearings, and replace with new. I can only guess that the Titan front wheel "cartrige" would be the same way. pulling one to find out, or finding someone who has an extra will be the best bet for the answer. front wheel bearings are not hard at all.
post #7 of 7 (permalink) Old 06-23-2010, 07:08 PM
hawaiiantitan's Avatar
finding someone who has an extra will be the best bet for the answer link
hawaiiantitan is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
I overtightened my wheel bearing...what to do? jdubslopro Titan Suspension 5 04-12-2010 04:40 AM
wheel bearing hub chirojoe Titan Wheels, Tires & Brakes 7 02-02-2010 06:54 AM
Driveshaft support bearing failure. arcitech1 Titan Engine, Transmission & Drivetrain 2 12-12-2009 07:05 PM
wheel bearing removal? Nismo4life Titan Suspension 11 05-24-2009 09:55 PM
Wheel Bearing Noise I Think sedonaguy Titan General Discussion 2 10-30-2006 07:45 AM
You may post new threads
You may post replies
