Originally Posted by bwalkertitan
The title explains it - I had my first oil change done (1400 miles) at the dealer with one of my free oil change coupons. Didn't crack the hood until I got home (20 miles from dealer) to check the oil level - that is when I found that the oil cap hadn't been replaced.
Anyone know of any problems that could result?
Thx.
Ok folks, I apologize but this is another time that I'm going to rant. I know I rant a lot (that's why my avatar is my wide opened mouth dog) but here goes. I know I've mentioned it before but I just don't like taking vehicles to the dealer for oil changes even if they are for free. If a dealer gave me free oil changes at the time of purchase I would ask for something of equivalent value.
I read on this forum before that dents were caused by the dealership during oil changes and now oil caps being left off. Is this really worth the risk? Why not ask for free oil filters and cases of oil for you to change the oil yourself. This should benefit the dealer. When you get an oil change for free or a special price, the oil that is used is often bulk oil that is inferior in quality that comes from an unmarked drum. A lot of times you simply don't know what you are getting.
Even if you see the guy open a $5.00 a quart bottle of Mobil 1, I still don't like anyone changing my oil. I'm anal about oil changes and from past posts that I have read I think most of you have a great concern about what is done to your Titan. When I change my oil I let it drain a minimum of 30 minutes. The thickest sediment usually comes out last. For best results in this regard you should not screw in drain plug until there is 1 drop per minute or less coming out. This usually takes over 30 minutes. For those of you who think that you really don't need to take that long-OK that's fine with me. But have you ever watched closely when you pay to have an oil change? The guy usually replaces the drain plug with a steady stream of oil still coming out!
This alone should make you want to change the oil yourself. You can do other things also that won't get done if you pay for an oil change. I always fill my oil filter with fresh oil before I install it. That way the engine gets a fresh gulp of oil sooner than it would if the filter was empty. Also when you change oil yourself you are forced to get under you Titan and look around. That's a good thing! You can look for possible problems before they happen. I could make the list longer but you get the idea.
It's true that it is easier paying for an oil change but the question is, "is it better?".
