Is a drivers window motor easy to change? - Nissan Titan Forum
post #1 of 6 (permalink) Old 07-11-2010, 11:41 AM Thread Starter
iTrader Score: 0 reviews
How hard is it to change out the drivers side window motor? What tools are needed? Thanks
beetlegus is offline
Advertisement
post #2 of 6 (permalink) Old 07-11-2010, 01:57 PM
hawaiiantitan's Avatar
Re: Is a drivers window motor easy to change?
Easy. 10mm socket, 3 inch extention, cordless impact, pocket screwdriver, and suction cups if you don't want to leave prints on the window glass.
FRONT DOOR GLASS REGULATOR ASSEMBLY
Removal
1. Remove the front door finisher.
2. Remove the hole cover over rear glass bolt.
3. Operate the power window main switch to raise/lower the door window until the glass bolts can be seen.
4. Remove the inside seal.
5. Remove the glass bolts.
6. Raise the front door glass and hold it in place with suitable tool.
7. Disconnect the harness connector from the regulator assembly.
8. Remove the bolts and the regulator assembly.
Replace the power window regulator motor.
Installation
1. Install the regulator assembly.
2. Connect the harness connector to the regulator assembly.
3. Align the glass and install the glass bolts.
4. Reset the limit switch.
5. Install front door finisher.
SETTING AFTER INSTALLATION
Setting of Limit Switch
1. Raise the glass to the top position.
2. While pressing and holding the reset switch, lower the glass to the bottom position.
3. Release the reset switch. Verify that the reset switch returns to the original position, if not, pull the switch using suitable tool.
4. Raise the glass to the top position.
CAUTION:
Do not operate the glass automatically to raise the glass to the top position.
Front door glass regulator assembly nuts and bolt: 7.5 N·m (0.77 kg-m, 66 in-lb)
Glass bolts: 6.1 N·m (0.62 kg-m, 54 in-lb)
hawaiiantitan is offline
post #3 of 6 (permalink) Old 07-11-2010, 04:37 PM Thread Starter
Finished it, thanks for the info. The replacement motor works although it is loud when the window is going up or down. It was a refurbished motor. But my window works now.
post #4 of 6 (permalink) Old 07-11-2010, 05:43 PM
SmokeEater98's Avatar
Hey sometimes my window is kind of catchy going up. Think the lift motor is going bad or should I just wait til it quits before I change it out?
"Life is tough but it's even tougher if you're stupid." -The Duke-
Airbox mod
Axle vent mod
unknown leveling kit
SmokeEater98 is offline
post #5 of 6 (permalink) Old 08-15-2010, 09:23 PM
bmack1022's Avatar
iTrader Score: 1 reviews
I just got my used 04 T. and he said he had the drivers dr motor replaced.
when i do the key trick to roll down the windows the passenger's goes down fine but the drivers goes down .5" at time. also the auto button, to hit once and make it go all the way down doesnt work anymore. is there anything i can do to get it back working stock?
bmack1022 is offline
post #6 of 6 (permalink) Old 12-28-2012, 01:42 PM
bmr4106's Avatar
Just replaced my drivers window motor on my '04 and it was not a problem. I watched the YouTube video and followed it precisely. One slight deviation. My old motor was not working at all, fortunately my window was all the way up. Unfortunately, I couldn't get to the forward bolt holding the the window glass to the regulator. So I loosened the rear regulator track completely, unbolted it from the glass (this is the section nearest the door catch, not the door hinges) and slid the regulator piece out. If you've been in there working, you know that this is the part of the regulator with the motor attached. Replaced the defective motor and put it all back together. Piece of cake.
bmr4106 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Drivers power window motor Guiseppe Titan Parts & Accessories 0 02-13-2010 06:00 AM
Easy exit drivers seat ? WVHUNTER Titan General Discussion 1 03-20-2008 11:19 AM
window motor vs. window regulator? Pugsly Titan Problems & Dealer Service 2 05-03-2007 09:31 AM
Wow, first oil change....so easy steves Titan General Discussion 3 06-01-2005 09:26 PM
Easy Oil Change for DIY'ers Orlando Titan Titan General Discussion 13 07-28-2004 09:37 PM
You may post new threads
You may post replies
