Power draw on battery with motor off? - Nissan Titan Forum
post #1 of 5 (permalink) Old 08-16-2010, 11:17 AM Thread Starter
iTrader Score: 0 reviews
How much power should be drawn off the battery with motor off?
sigep1967 is offline
Advertisement
post #2 of 5 (permalink) Old 08-16-2010, 01:15 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: Power draw on battery with motor off?
Should be very minimal
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #3 of 5 (permalink) Old 08-16-2010, 01:28 PM Thread Starter
is 120 milllamps too much?
post #4 of 5 (permalink) Old 08-16-2010, 01:43 PM
You have to let the ECU go to "sleep" before you can take a reading on the "phantom draw".
At least a 30 period
Honeykeeper did a test, his post
I decided to test the phantom load/leakage at the battery on my Titan.
With initial hook-up of power one can see the integrated circuity on our Titan requires a breif "charge-up" of ~1 amp or 12 watts.
If the engine isn't turned on within 30 minutes most circuits cleverly step down to a conservative "idle/sleep mode".
Here's the average "phantom load/leakage" readings from connect to 5 min. to 30 minute... idle/sleep = ~ 20 mA.
0.24 watt/hr. is the idle leakage/phantom load. This would only effect a battery sitting for weeks without a charge unless you have a non OEM combo deep cycle battery installed.
Connect = ~909 Ma.......5 minute = ~124 Ma.......30 minute = ~20 Ma = idle/sleep-phantom load.
VVV..............................VVV.............. ................VVV
post #5 of 5 (permalink) Old 08-17-2010, 04:25 AM Thread Starter
Well was not parasitic draw on the battery it was a bad battery! The frst place I took it to said the battery was fine. After checking everything with a meter took it somewhere else. Battery was only getting up to 375 cranking amps voltage was good just no amps.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Power window motor mkelee Titan Parts & Accessories 3 04-17-2008 05:52 PM
motor no take off power big lou Titan Engine, Transmission & Drivetrain 4 02-03-2008 08:14 AM
Draw-Tite weight distributing hitch & deep cycle battery rcantu Buy/Sell 7 11-04-2006 12:12 AM
Draw-Tite weight distributing hitch & deep cycle battery rcantu Buy/Sell 14 07-09-2006 07:59 PM
You may post new threads
You may post replies
