Old 05-24-2004, 01:06 PM   #1 (permalink)
Service Manual
I have purchased a 1-day subscription to the Service Manual, but when I ge to the PDF page, it says that the files do not exist...can somebody tell me what I am doing wrong??
titanized is offline   Reply With Quote
Old 05-24-2004, 01:09 PM   #2 (permalink)
cshaw's Avatar
I couldn't even find it at first, but was able to locate it using the site search function.
Crappy Gold Color
1983 Toyota P/U
Hey, it's paid for and the radio sounds better then my old Titan!
cshaw is offline   Reply With Quote
Old 05-24-2004, 01:12 PM   #3 (permalink)
I found it, just all the files say they do not exist...????
Old 05-24-2004, 01:21 PM   #4 (permalink)
coco's Avatar
Just to clarify. You have to go through each section and save them one at a time 40 something seperate files. If you save the first one and then try to access the manual on your Pc you will get the do not exist messages.
Sorry in advance if this is off base.
XE CC White
Born on 12/03
coco is offline   Reply With Quote
Old 05-24-2004, 01:35 PM   #5 (permalink)
I don't know...I did try to save the first one, but it said this process cannot be performed...then all the other files say they "do not exist"...??? Any more help is appreciated.
Old 05-24-2004, 01:45 PM   #6 (permalink)
coco's Avatar
OK. My subscription has expired so I can't check the files. I did this download last Friday. From memory here's the process I think I used.
From the 'Inside Publications' menu seclect 'Find Publications'
Fill out the form (you just need to enter Titan).
A pop up window comes up with a little eye next to the service manual click on this.
A new window opens with the PDF manual displayed. Use the diskette icon to save. Then use the bookmarks to go to each section and save these.
If this doesn't help then where exactly are you seeing your error?
XE CC White
Born on 12/03
Old 05-24-2004, 02:03 PM   #7 (permalink)
Good Memory. That is exactly what I have done...when I click on any of the Titles on the Bookmark...a small pop-up window appears stating that the PDF does not exist. Ex. On the Suspension Icon, there is Front Suspension, Rear Suspension, and Road Wheel & Tire. I clicked on the Front Suspension...the pop-up appears stating that the FSU.pdf does not exist. I emailed and called, I am waiting for a return call/email. I can view the Quick Reference, the Foreward Page, the Comment Sheet, and the 3 Qick Reference Charts, and thats it...all the other don't exist. Thanks for the help!!
Old 05-24-2004, 02:08 PM   #8 (permalink)
coco's Avatar
Looks like you'll have to wait for their support to sort this out.
XE CC White
Born on 12/03
Old 05-24-2004, 02:47 PM   #9 (permalink)
cttitan's Avatar
Is this from a file you have downloaded? It will say that in a downloaded file if you haven't downloaded the other files.
As previously mentioned you have to download each separate section of the manual, I ended up with 45 files at a total of about 90megs. Even after that they don't link up from the index you have to go to each file separately.
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Rockwood 2306 Travel Trailer
Equalizer Hitch, Prodigy Controller
cttitan is offline   Reply With Quote
Old 05-24-2004, 02:57 PM   #10 (permalink)
I Got It!!!
All of it...There was something wrong with my Adobe Acrobat(sp). Reinstalled it and was able to view the Service Man. Thanks for all the quick replies...This site is awesome.
Old 05-24-2004, 05:00 PM   #11 (permalink)
SUBTITAN's Avatar
titanized, This happened to me although I was using reader 5.0. I had to go into the preferences and make sure that it opened the pdf file in the browser, there is a check box for this. Hopefully if you run into this problem again this will fix it.
2004 Titan CC 4X2 LE Canteen
"SUB out going sinker"
SUBTITAN is offline   Reply With Quote
