Originally Posted by ehill
Does Anybody Know If The Xm Fixes The Radio Problem Local Stereo Shop Tod Me That It Works Thru A Fm Modulator And Would Still Have The Same Problem Unless I Used The Dealer Kit.
I have an XM Commander. There are two ways to connect it to the Nissan head unit - either via the FM radio or the AUX input. Connected thru the FM radio the sound suffers from the noisy front end on the radio and overall lack of frequency response (no lows) of the FM radio. Connected via the AUX input the level is low relative to the CD volume but there is ample volume control range to get well above a normal listening level and the frequency response is much better than the FM radio.
To my recollection both Delphi XM receivers also have AUX outputs if you are considering those units.
The Nissan XM receiver works directly into the head unit and does permit use of the steering wheel controls which the 'universal' receivers will not without additing additional electronics.
