Everything Eakes said is right on. As a general rule, you should have speakers that have a slightly higher RMS rating than the amplifier's RMS rating (how much higher is up to the installer, everyone says something different.. go too high and the speaker will damage itself by clipping). For your 75 watt RMS you are ok to get those 100 watt RMS speakers for the front. Like Eakes said, if you put those 60 watt RMS speakers in the rear, and frequently sustain high volumes, the speaker will most likely blow.
A couple of things you can do... look at HIGHER quality (usually more expensive) speakers for the rear. Since they are a smaller size, a higher quality speaker of better construction will be needed to get closer to that 100 watt RMS.
or... since it is mostly the lower bass frequencies that cause the speaker to excurd farther than it is intended, which causes premature wear ("blowing a speaker"), You can try some 'bass blockers' which are kind of like little crossovers except much cheaper. They block a range of lower frequencies associated with bass notes. You can get them in 150, 600, and 800 hz (maybe more now, haven't installed them in a couple of years). Sounds like you should go with the 800 hz bass blockers for your high powered application (over 50 watts). These get wired inline, one per speaker on the positive wire or directly to the terminal, and will help prolong the life of a cheaper speaker that would otherwise be receiving too much power.
You can find these at Crutchfield.com or at your local Best Buy store.. probably at Circuit City or Good Guys also.
As for your new question: You CAN run two speakers off of one channel. in my opinion unless you are going to do some magician work with positioning the speakers elsewhere in the cab, you are better off running one speaker on each channel. It is what is intended for the truck's door panel. You won't be able to put TWO 5.25 inch speakers in the rear doors unless you do some cutting.
I think that by running two speakers off of one channel you might lose some signal clarity and possibly even have a little distortion. You might even be under powering the speakers which can cause clipping and result in damage that way also. Might not happen, but... just get better speakers.
Splitting the channel really only works well when you have a MONO subwoofer amplifier and more than one subwoofer.
Good luck!
-Paul
KC XE Smoke
