Old 06-12-2004, 10:05 PM   #1 (permalink)
bwalkertitan's Avatar
Differential Fluid Warning!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well, I had previously checked my rear diff fluid (but not the front) because of the warnings on this site. Today I decided to drain both the front and rear and put in Mobil 1 synthetic 75-90.
The rear went off without any issues, however when I checked the level of the front with my pinky, I couldn't feel any fluid as far as my pinky could reach down into the diff!!!!!!!! When I drained it, the color was still looking very good, but personally, it was a bit scary since I have been offroad a couple of times already in 4HI. I then filled it and all is good now.
The warning: check your front even if the rear is fine, don't make the assumption that because one is good, the other will be too.
2004 Smokin Nissan Titan SE CC 4x4
-Big Tow
-Offroad
-Banks
-K&N Drop-In
http://www.calidrifting.com
bwalkertitan is offline   Reply With Quote
Old 06-13-2004, 12:39 AM   #2 (permalink)
WIS-key's Avatar
I experienced the same thing on my front diff. I could not touch any fluid with my pinky using the fill hole. So, I decided to drain and refill both. The fluid looked perfect coming out and there was very little "swarf" on the drain plug.
At any rate, both diffs have been drained and refilled with Mobil 1 75W-90...
-Rob
WIS-key is offline   Reply With Quote
Old 06-13-2004, 05:50 AM   #3 (permalink)
Mike H.'s Avatar
Same here. Mine took something like 16 oz to bring it up. Check your front ends guys.
Mod links (clickable):
Old 06-13-2004, 08:00 AM   #4 (permalink)
-Rob
I couldn't reach my front diff oil level either, but I had put quite a few miles on mine. With winter driving amounting to several hundred miles worth of snow and ice storm commuting. When I drained it, the oil was fairly dark and there was about an eighth of an inch of metal mung (technical term) on the front plug magnet. It seemed that not very much oil came out when I drained it (just a few seconds worth). The rear drained for quite a bit longer than the front. Both of them seemed to hold about two quarts of new oil each (Mobil 1 75W-90).
I'm sure glad I checked this before next winter. I'll be sure to keep a close eye on this in the future.
Cary
Red Brawn, SE, CC, Big Toe, Off Road, Ute bed
10000+ miles on Titan #2211- 11/03
Last edited by GreenmtnTitan; 06-13-2004 at 08:19 AM. Reason: Wrong oil amount given
GreenmtnTitan is offline   Reply With Quote
Old 06-13-2004, 08:06 AM   #5 (permalink)
I would recheck those amounts - between the two, I used approx 4 quarts.
Also, I had two magnetic plugs on the front - not sure if this is standard.
-Big Tow
-Offroad
-Banks
-K&N Drop-In
Old 06-13-2004, 08:17 AM   #6 (permalink)
OOPS, wrong amount!
You're right! Sorry about the miss information, I did use 4 full quarts between the two diffs. Both plugs on the front did have magnets, the upper one didn't have much "mung" though.
Thanks,
-Cary
Red Brawn, SE, CC, Big Tow, Off Road, Ute bed
Old 06-13-2004, 12:53 PM   #7 (permalink)
casique's Avatar
How hard is it to get to the front diff? Did you put the truck up on ramps?
2004 Radiant Silver Titan CC LE 4X4, DVD/NAV, big tow, no-offroad, Volant, tinted windows, utili-bed extender, Retrax Bed Cover, Zoomer Exhaust, Westin Bull Bar w/PIAA driving lights, Silverstars hi/low/fog, bug guard, Nissan Aluminum Diff Cover, smoke chrome grill cover and sun roof visor.
casique is offline   Reply With Quote
Old 06-13-2004, 12:57 PM   #8 (permalink)
nope no ramps - I just crawled under there - little tight maneuvering though. Had to take off one skidplate to be able to access the filler plug.
-Big Tow
-Offroad
-Banks
-K&N Drop-In
Old 06-13-2004, 06:39 PM   #9 (permalink)
I haven't checked my rear but the other night I had a little whine only on light accel, it went quiet when coasting. Makes one wonder. I will have the dealer check them when doing my warrenty work. Mind you that i'll check them 1st, you guys that were low should tell your dealer, with my luck right @ 60001 it would let go.
dandy is offline   Reply With Quote
Old 06-14-2004, 06:11 AM   #10 (permalink)
WIS-key's Avatar
Same here - four quarts between the two and the both front plugs are magnetic.
-Rob
Old 06-24-2004, 05:15 PM   #11 (permalink)
My back was fine and I almost skipped the front rather than take off the skidplate. Glad I didn't because I couldn't reach any with my finger. There is mung on my upper plug in front and none on the back dif. which was full.
Old 06-26-2004, 07:51 AM   #12 (permalink)
FLfinfan's Avatar
Both of mine were low. Drained and refilled the rear with Mobil 1 syn. The front just got topped off with Valvaline regular gear oil. I will eventually drain and refill the front with Mobil 1 syn also.
Drained the motor oil at 800 miles and put in Castrol GTX. Now have 1900 miles on her. We are taking a long summer trip at the end of summer so I might change the oil again before and after the trip. Also might change the rear diff oil after the trip (3000 miles round trip). Might be overkill, but oh well. Just wanna take care of the beast.
FLfinfan is offline   Reply With Quote
Old 06-26-2004, 12:10 PM   #13 (permalink)
ekool's Avatar
This would make an excellent FAQ entry... I'm going to work on that right now.
ekool is offline   Reply With Quote
Old 06-27-2004, 09:02 AM   #14 (permalink)
Titan Ken's Avatar
I had my first oil change done at the dealer (1922 miles), and asked that the front and rear differentials be checked. The service advisor said that was done during PDI (pre-delivery inspection). I said I'd like to be sure. He said management doesn't like them doing "silly stuff", but since the service manager wasn't there (Saturday), he'd have it checked for me.
He reported the level was ok in both.
Ken
'04 SE CC 4X4
Popular Pkg w/ Power Capt.
Radiant Silver
Leer 100 XQ Canopy
Aux. Driving Lights
Aux. Backup Lights
Prodigy Brake Controller
Titan Ken is offline   Reply With Quote
Old 06-27-2004, 09:19 AM   #15 (permalink)
Ken
If a Nissan dealer says this to me I think I will ask for it in writing so I can show it to Nissan USA after they spend lots of $$$ replacing the rear end on my Titan. You would think since this is a problem with Titans, Nissan would want to check the differential on all Titans brought in for service for any reason.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
