35" Nitto Mud Grappler fit with mini lift??? - Nissan Titan Forum
post #1 of 36 (permalink) Old 02-11-2011, 01:49 AM Thread Starter
iTrader Score: 0 reviews
Just ordered my Nitto MGs 35/12.5/r18 to fit on my stock 18x8 wheel, ive heard mixed results in different forums all over and was wondering if this will fit my 2007 2wd. I installed the PRG 2.5" front, 1.5" rear mini lift.
wesgraves616 is offline
Advertisement
post #2 of 36 (permalink) Old 02-11-2011, 08:04 AM
Pops's Avatar
iTrader Score: 1 reviews
Re: 35" Nitto Mud Grappler fit with mini lift???
They can but you'll need to do the pinchweld mod and they will still rub under some heavy articulations, so your Offroad capabilities will be limited... 33/12.5-18 are a Perfect fit under a MiniLift...
2005 Armada LE 4x4
Pops is offline
The Following User Says Thank You to Pops For This Useful Post:
StarsBoysfan (02-20-2011)
post #3 of 36 (permalink) Old 02-11-2011, 08:46 AM Thread Starter
Was definitely planning to do a PWM after they were installed to minimize the amount of cuts at the pinch weld, but if it calls for it ill cut as much as i have to. I really want the 35" because the 33" looks smaller than what i hoped for in the look of the vehicle. Do you think i should make cuts before the tires get put on? i will be driving back home for about 30 miles from the shop to the house. An thank you for your help!
post #4 of 36 (permalink) Old 02-11-2011, 09:33 AM
Colten K's Avatar
Go with the 33's your just gonna have problems with the 35's. My 35's rub on my 6" lift. So for sure there gonna rub on a mini lift.
TINA, 2005 4x4.
some off road stuff,some exhaust stuff,some sterio stuff, some bright lights, some bedlined stuff,some tinted stuff,some preformance stuff, some custom stuff!
Colten K is offline
post #5 of 36 (permalink) Old 02-11-2011, 10:06 AM
Pops's Avatar
I don't remember his username but there was a kid in Nebraska who a year or two ago did exactly what you're wanting to do... He was happy because he said that he never offroads... I don't understand why the hell anyone would want to lift a truck to fill inside the fenderwells with 12 miles per gallon - heavy arsed Offroad tires that they cannot even offroad with because they'll rub too much... I mean, do you really wanna be having to fill a full tank of gas every 250 miles just to have a poser street queen??
33's are not as small as you might think they are... They honestly DO fit a Mini-Lift perfectly.. But either way, you have your answer.
This is 33's w/ a PRG Mini-Lift:
2005 Armada LE 4x4
Pops is offline
madrock (02-11-2011)
post #6 of 36 (permalink) Old 02-11-2011, 10:49 AM Thread Starter
Im absolutley eventually going to take it off road, when i have time of course :-) I dont want to waste the money on the tires if im going to be adding on the 4" spindle lift for 2wd from gregs website (PRG). But i also want to go for the mean aggressive look when im not on the trails. The gentleman from nebraska that did it the same said he only needed the PWM and he was golden with a 2" mini lift and i have a 2.5". The reason im getting the tires now and not when i put on the additional spindle lift is because my rear tires are almost bald and i dont want to waste the $$ on getting smaller tires now then spending another $1200 in a few months. Again i appreciate your help with this greatly. You did great work on your Armada btw, looks very nice, sir!!!
post #7 of 36 (permalink) Old 02-11-2011, 11:04 AM
Pops's Avatar
Oh, that's right, I forgot about you going for the 4" spindle later... The 2" was on a 4x4 and your 2.5" is on a 2wd... 2wd come 0.5" shorter than 4x4 from the factory so your end result is the same... Thanks for the compliment!!!
The Mud Grapplers have larger side lugs than most other tires, that will be your downfall.. If you get something else like Cooper Discoverer STT or Toyo Open Country M/T, they will fit in a bit better gut you will still need to get jiggy with a sawzall....
I sorta did what you're going but I stuck with 33's... In all honesty, I'm really glad I did but I will admit they are a little small under a 6" Lift, but they still work very well...
Here's 33's under a 6" Lift:
Pops is offline
post #8 of 36 (permalink) Old 02-11-2011, 11:12 AM
madrock's Avatar
iTrader Score: 27 reviews
I like your stance, Pops. I will be sticking with a lighter weight 33" AT tire this time. I like the Hankook ATM but since my work cut my pay, it may be awhile before I can get rid of my 285/60/18 tires.
2008 Nissan Titan XE Crew Cab with Popular Package
PERFORMANCE: BullyDog PP | Airaid MXP 4" Missile Intake | Stillen High Flow B-Pipes | Flowmaster True Dual Super 40 | Tru Cool 4588 Transcooler
SUSPENSION: 08+ 4x4 Coils | Bilstein 5100 Struts| 1.5" PRG Blocks | Bilstein 5125 Shocks
GOODIES: HID Low Beam and Fog Lights | 4 Kragen HID's on Defiant Light Bar | Window Screen Mod | Axle Vent Mod | Custom Traction Bars | OnFair Headrest Monitors | TonnoPro TriFold Tonneau | Fumoto Drain Valve | Hankook Dynapro ATM 275/60/20 | 20x9 Ballistic Jesters -12 offset
OTHER RIDE: 2007 Jeep Commander Sport 4x4 | 4 Rigid Duallys | Custom Light bar | Plasti Dipped Wheels | Hankook Dynapro ATM 245/70/17
madrock is offline
post #9 of 36 (permalink) Old 02-11-2011, 11:36 AM Thread Starter
i dont mind "getting jiggy with my sawz-all" ha ha. The 6" on your rig looks great and the exact overall lift im goaling for in end. The 33s look a little small with that big of a lift unfortunately. I just dont want to spend the $ on the 33s then need to spend it again in a few months. But if you are highly recommending the 33" mud grapplers over the 35s then i will follow your advice. This is why i asked :-)
post #10 of 36 (permalink) Old 02-11-2011, 11:59 AM
Pops's Avatar
... But if you are highly recommending the 33" mud grapplers over the 35s then i will follow your advice. This is why i asked :-)
My personal opinion is suggesting that... Ya know, I just had a flashback... Alot of tire shops like Discount Tire usually offer a Test Drive to let you take it for a spin down the street then swap them out if they won't work... You might give that a try... I would also suggest looking at either Toyo M/T or Cooper STT in 35" for comparison's sake... Whatever you do, take your time and make sure it's what YOU want to do... I just know that there's only so much you can cut and 35" Mud Grapplers under a mini-lift can push it to the limit...
2005 Armada LE 4x4
Pops is offline
post #11 of 36 (permalink) Old 02-11-2011, 12:20 PM
Mattastic13's Avatar
iTrader Score: 3 reviews
Just to put it out there. I have the Rough Country 6 inch lift with Nitto Trail Grapplers and I will have to be doing some cutting this weekend cause I am having rubbing issues at full steering lock
Mattastic13 is offline
post #12 of 36 (permalink) Old 02-11-2011, 12:29 PM Thread Starter
we will be able to fit it on the truck but i cannot return them after they hit pavement. ive looked at the toyo's and the coopers. they are nice tires and all and the quality is there but im looking for the aggressiveness of the Nitto's. i would really like the 35s but if its an impossible fit i guess i can deal with the 33s. These tires will dominate on the trails and will not give me any trouble even with the 2wd.
post #13 of 36 (permalink) Old 02-11-2011, 12:34 PM
T-Dog23's Avatar
Thats what you get with a rough country lift...a "rough" ride. JK
SOLD2008 Titan 4x4 SE, 6" procomp stage 2 lift (coil-overs and MX6 ajustable shocks), PRG Drive Shaft Spacer, 35" Procomp xtreme M/T tires, 20x10 Black Rockstars, volant cool air intake, JBA Pipes to a Dynomax Bullet Dumped w/ resonated tip, headlight mod, 2 12" Kenwood subs in tech12volt box, HID 8000k lights HI/LOW, blacked out.
T-Dog23 is offline
The Following User Says Thank You to T-Dog23 For This Useful Post:
Mattastic13 (02-11-2011)
post #14 of 36 (permalink) Old 02-11-2011, 01:47 PM
Pops's Avatar
Full lock??? What's that??? My steering wheel hasn't seen full lock for a couple years now because Reverse works alot better.
2005 Armada LE 4x4
Pops is offline
post #15 of 36 (permalink) Old 02-11-2011, 01:51 PM
Pops's Avatar
we will be able to fit it on the truck but i cannot return them after they hit pavement. .
In that case, find a way to to turn them where they are closest to the rear of the fenderwell and bounce on the truck to see if they rub when up in the fenderwell... Or just roll that one wheel up onto a floor jack and lift it with the steering wheel slightly turned enough...
2005 Armada LE 4x4
Pops is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
18" XD Monster Black Nitto Trail Grappler 285/65-18 33" LaxThanatos Discount Tire 9 04-05-2012 07:47 AM
325/65/18 Nitto Terra Grappler PRG spindle lift andre Titan Wheels, Tires & Brakes 11 10-21-2010 11:07 AM
20" raceline rims on 33" nitto terra grappler tires MIKE858 Buy/Sell 27 04-11-2010 12:08 PM
Just Released: New 16" - 24" sizes of the Nitto Trail Grappler M/T PostRelease Titan Parts & Accessories 0 01-21-2010 06:59 AM
35" nitto with mini lift. illusionsoflife Titan Wheels, Tires & Brakes 5 11-15-2008 11:13 PM
You may post new threads
You may post replies
