Old 06-23-2004, 08:22 AM   #1 (permalink)
Colorado's Avatar
Subwoofer question...
This is the first truck I've ever owned that has a subwoofer, so I'm looking for a litle edumacation. The sub seems to work fine when I crank the hell out of the music, but doesn't seem to fire when the volume is in the "normal" range. Is this the way subs work, or should there be better response at the lower volumes? It's not a big deal, I'm just more curious than anything. Maybe there's some adjustment that I'm not aware of.
Colorado
2004 Red Brawn LE KC
Born 12-16-03
Colorado is offline   Reply With Quote
Old 06-23-2004, 08:58 AM   #2 (permalink)
Sammy Sandbag's Avatar
The only adjustment you have with the factory sub is to up the bass on the audio control. No real other options other than going with an aftermarket box/sub/amp that will give you more control. It's probably working "normal", just not to your standard.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 06-23-2004, 11:28 AM   #3 (permalink)
bmwR1150R's Avatar
If your Titan has a Rockford Fosgate, on the controls where you can adjust the bass, trebel, etc., you'll see an option called 'SSV'. It'll probably be set to 'low'. You'll want to adjust that to 'mid' or 'high' to hear (or feel) the subwoofer more often.
Johnathan
2004 Nissan Titan SE
Red Brawn
Big Tow w/ VDC
Off Road
Utility Bed
Rockford Fosgate
bmwR1150R is offline   Reply With Quote
Old 06-23-2004, 02:05 PM   #4 (permalink)
Speed Sensitive Volume shouldn't have anything to do with the adjustment to the sub, it just adjusts the volume overall according to the vehicle speed. Setting it to high will only make the volume drop off when you are driving slow then high when at higher speeds. I suggest you leave it off unless you like having your volume go up and down as you drive.
-Counsel Yourself
Old 06-23-2004, 06:34 PM   #5 (permalink)
bigmd10's Avatar
what does the other control help, mid i think its called. my last truck only had bass and treb.
04 Titan Crew Cab LE Silver, Born on: 1 Dec 2003
2WD/Sunroof/Side Air Bags
Big Tow/Navagation/DVD
Utility Bed/Bed Extender/Bed Tray
bigmd10 is offline   Reply With Quote
Old 06-24-2004, 06:56 AM   #6 (permalink)
Mid level adjustment. Treble being the high freqs, mid being the medium, and bass being the low.
-Counsel Yourself
Old 06-24-2004, 07:09 AM   #7 (permalink)
GemInI's Avatar
Anyone who doesnt have a sub and the 6 speaker package try hooking up one? Now a days....the factor mids/highs put out a good sound. Of course it doesn't generate alot of bass. In one of my celica's I installed 6" subs in the doors and had a Mid/tweater combo with the mids in the back and the tweaters up front. It sounded really good. I dont want to have a ground shaking system, I'd just like to add a little more boom to it. How do you guys think just putting some 8's or 10s under the back seat would sound? Anyone know how powerful the 6 disc changer is?
Radiant Silver
2WD Crew Cab SE
Pop. Package
Captain's Chairs
20% Tint
OEM Bug Deflector
GemInI is offline   Reply With Quote
Old 06-24-2004, 07:13 AM   #8 (permalink)
I just finished putting a 10" under the back seat. Stand by later for a new topic on it.
-Counsel Yourself
Old 06-24-2004, 10:57 AM   #9 (permalink)
bmwR1150R's Avatar
All I know is that when I set the SSV to mid or high, I hear (feel) the subwoofer kick in. When it is set to low, I get nothing.
Johnathan
Red Brawn
Big Tow w/ VDC
Off Road
Utility Bed
Rockford Fosgate
Old 06-24-2004, 11:01 AM   #10 (permalink)
I don't know how that is possible considering all SSV does is adjust the volume according to speed. You can do the same by just turning the volume up or down.
-Counsel Yourself
Old 06-24-2004, 05:57 PM   #11 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
It's probably jacked like the rest of the raido's
More Pic's Here
SarkaZm is offline   Reply With Quote
