Belt noise on startup? - Nissan Titan Forum
post #1 of 16 (permalink) Old 03-21-2011, 08:28 AM Thread Starter
priapism's Avatar
iTrader Score: 0 reviews
So my 08 LE w/ 46k on the clock makes a racket of belt noise on startup. Some squeaking and tapping. Is this normal? I bought it used so I don't know exactly what has been done to it as far as maintenance goes.
08 LE CC 4x4
priapism is offline
Advertisement
post #2 of 16 (permalink) Old 03-21-2011, 08:32 AM
gweasel77's Avatar
Garage
iTrader Score: 6 reviews
Re: Belt noise on startup?
Every once in a while, when it's really hot, wet & humid outside, mine will squeak for a few second's when i first start it, after sitting all night. I goes right away though...
2005 NISSAN TITAN SE KC
IRCVK56/TEAMVK56 Crew Chief
performance:
UP/REV (RB's TUNED)
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF 2 Core Rad w/ Fumoto QuikValve / Nismo 170*F T-Stat / TruCool SR4588 / Nismo LT Header's / BerkTech B-Pipes w/ MF Hi-Flows / FlowMaster Y-Pipe / BORLA XR1 / Relentless RPM Gen2 Catch Can / Detriot TruTrac LSD / Grounding Kit / Burnout Mod / IAT "Reaper Mod" / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 Full Syn 5W30
exterior/suspension:
Ruff Racing R286 22"x9.5" Chrome w/ 305/45/22 Toyo Proxes ST2's / Slotted "Cryo" Frozen Rotors / Hawk LTS Pads / Gatorback Poly-V Serp Belt / Stillen Diff. Cover / PRG Street Bars / Helwig RSB / Bilstein 5100's & HD's / MOOG Springs / SpringTech Drop Shackles / PRG camber bolts / SolarGard Tint / CF Mirrors & Door Handles / Custom CF wrapped Interior / Morimoto XB 6K HID's / Full LED Retrofit (Interior & Exterior) / LED Cube Fogs / Diode Dynamics Tails, TRS Switchback Turn Signals / Morimoto XB Reverse
NEW PB 2014: 1/4- 13.55 @ 98.5MPH
Next Mods: CAJUN 2.5"-3" Y-Pipe Kit
gweasel77 is offline
post #3 of 16 (permalink) Old 03-21-2011, 08:44 AM
iTrader Score: 5 reviews
time to change the belt after that many miles
2014 Silver Ram Laramie 4x4 w/ leather and Alpine sound
2008 Red Brawn Titan SE 4x4 Popular package
ArmyAviation is offline
post #4 of 16 (permalink) Old 03-21-2011, 09:02 AM
HudsonValleyTitan's Avatar
Take it to the dealer. There's an issue with the belt tensioner apparenty. They replaced the tensioner and belt under warranty. And I only have 25k on my 08.
HudsonValleyTitan is offline
post #5 of 16 (permalink) Old 03-21-2011, 10:15 AM
sudden urge's Avatar
iTrader Score: 4 reviews
Lightly spray some water on the underside of the belt while you hear that noise. If the noise disappears immediately, replace the belt. I'm running the Goodyear Gatorback 97.5" serpentine belt.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is offline
The Following User Says Thank You to sudden urge For This Useful Post:
gweasel77 (03-21-2011)
post #6 of 16 (permalink) Old 03-21-2011, 10:21 AM
spray some belt dressing on the belt before you start it and see if it does it.
Owner Of A White 2007 Nissan Titan King Cab,
www.topchoicedecals.com Decals And Custom Decals works part time at www.guysafterconception.com
jessestylex is offline
post #7 of 16 (permalink) Old 03-21-2011, 10:27 AM
NEVER use belt dressing on a serpentine belt.
post #8 of 16 (permalink) Old 03-21-2011, 10:30 AM
why not? whats the difference
post #9 of 16 (permalink) Old 03-21-2011, 10:39 AM
Do not apply “belt dressing” to a serpentine belt in an attempt to quiet a belt or cure slipping. Belt dressing is a gooey, tar-like substance designed to cure V belt slipping by making the belt sticky. At best, it is a temporary palliative, even on a V belt. But, when applied to a serpentine belt, the dressing will be spread into the pulley grooves. Once there, it will attract and hold dirt and grit. The dirt will start the belt slipping again and all of the dirt and belt dressing will have to be cleaned out of the pulley grooves before a new belt is installed.
post #10 of 16 (permalink) Old 03-21-2011, 10:45 AM
ok, i learned something new today
post #11 of 16 (permalink) Old 03-21-2011, 11:53 AM
my 08 does the same thing 34,000 miles.
j12racer is offline
post #12 of 16 (permalink) Old 03-21-2011, 12:44 PM
AZPRO4X's Avatar
iTrader Score: 8 reviews
I have just learned to deal with it. I have had the TSB done and it came back. Mine only does it during the winter for a few seconds.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
post #13 of 16 (permalink) Old 03-21-2011, 12:53 PM
DeadRiver's Avatar
Send a message via AIM to DeadRiver
is it dirty battery terminals causing the alternator to overwork upon start up?
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
PA Chapter Director
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
post #14 of 16 (permalink) Old 03-21-2011, 01:11 PM
No...........
post #15 of 16 (permalink) Old 03-22-2011, 04:42 PM
253XE's Avatar
Garage
Replace the belt! My belt started making noise at 20k (08 XE) Nissan was happy to replace it, and wash the truck! Sometimes the stealerships are good for something!!
253XE is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Noise right at startup & 1-2 min after shutoff?? Lurchdubious Titan General Discussion 8 10-22-2006 01:52 AM
HELP! Grinding noise on startup! Chris93Si Titan General Discussion 7 07-11-2006 12:54 PM
Lifter noise on startup titanwild Titan Engine, Transmission & Drivetrain 16 03-10-2006 07:11 PM
noise at startup?? fgb Titan General Discussion 1 04-01-2005 12:55 PM
You may post new threads
You may post replies
