Old 07-11-2004, 07:17 PM   #1 (permalink)
TNTITAN's Avatar
wipers squeaking and skipping
Anyone elses wipers do this? I got a new pair of factory blades and it made no difference. I put on Castrol windshield treatment and it got worse. Now what? I find it very annoying.
Matt
2004 Silverado Z71
Knoxville, TN
TNTITAN is offline   Reply With Quote
Old 07-11-2004, 08:39 PM   #2 (permalink)
Try Rain-X. If you don't like it, Windex will take it off.
Drew
2004 Titan XE KC 4x2
Drew is offline   Reply With Quote
Old 07-11-2004, 08:49 PM   #3 (permalink)
BigRedTitan's Avatar
Mine run as smooth as I've ever seen wipers run. No skipping or squeeking or any other annoyances. Haven't put anything on the windshield other than plain ol' car wash solution.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 07-11-2004, 10:57 PM   #4 (permalink)
overdose's Avatar
same here, no problems with wipers. Never used any rain-x or castrol windshield treatment, just good'ol car wash solution.
overdose is offline   Reply With Quote
Old 07-11-2004, 11:29 PM   #5 (permalink)
Send a message via AIM to TITAN UP !! Send a message via Yahoo to TITAN UP !!
Lightbulb
Try rubbing alcohol to treat the blades before installing. It may help but I really do not know. I have a slight squeal and skip with mine but I just let it "slide" you know.
TITAN UP !!
Deep Water Blue,XE,CC,4X2
UTILITRAC SYSTEM
Bed Extender
Tow Package
Have you hugged you Titan today?
TITAN UP !! is offline   Reply With Quote
Old 07-12-2004, 08:02 AM   #6 (permalink)
avroflyer's Avatar
On the subject of the windshield wipers, anyone else have pitifully weak washer heads? I pull the windshield washer column and the damn head nozzles just "spit" out the fluid on the lower part of the windshield. Eventually it gets all around the windshield (barely though), but it is quite weak! Yes, the reservoir is full
_________________________
Jim Reeves
Canteen (its not for everybody!!!) King Cab SE 4X2
Off-Road, Big-Tow, RF power-captain
Mods:
PRG Front Level
Magnaflow single 3" in dual 2.5" out exhaust
K&N Series 77 Intake
MAAP Challenger Tube Steps
Carriage Works Billet Grille
American Racing Burst Wheels
Aluminum Dash Accents
Aluminum Pedals
avroflyer is offline   Reply With Quote
Old 07-12-2004, 08:03 AM   #7 (permalink)
Driller's Avatar
Bosch Wipers - Love these!
http://www.boschusa.com/AutoParts/WiperBlades/
Driller is offline   Reply With Quote
Old 07-12-2004, 10:48 AM   #8 (permalink)
I scrapped my original blades when they were only two months old because they were streaking and skipping. Bought a set of premium trico blades at about $10 each. They really work well. Much better than the $4 blades. Using alcohol on the blades does help.
Streetrodder is offline   Reply With Quote
Old 07-12-2004, 10:57 AM   #9 (permalink)
You might try cleaning the nozzles with a needle. I was having problems in the winter when I first got the truck and I drained everything, removed and flushed all the hoses, cleaned the nozzles and then re-filled with Prestone washer fluid. Mine work o.k. now.
Old 07-12-2004, 11:20 AM   #10 (permalink)
VShortt's Avatar
Try a set of Bosch "Micro Edge Excels". They are undoubtedly, the best blades that I have managed to get my hands on yet. Just remember, you must buy the entire blade and not just the wiper refill. The refills will not fit your stock blades. I think they are about 10-12 bucks a blade but they are certainly worth it. Not to mention, it will get cheaper on your next go-round because you will not have to buy the blades again...only the refills.
New List of Mods Coming soon
Old 07-12-2004, 11:31 AM   #11 (permalink)
FLfinfan's Avatar
My Frontier and Xterra OEM blades skipped and chattered so I switched to the Bosch blades mentioned above. They were great. I will probably have to do this with the Titan also.
FLfinfan is offline   Reply With Quote
Old 07-12-2004, 06:35 PM   #12 (permalink)
Had that proplem on a new car 3 years ago. Took it to the dealership and they got out a wiper arm angle gauge to check it. Said the arm was slightly "rotated". They adjusted and we thought we were happy. Well, that fix didn't work. I eventually wore tired of the rattling and threw a crescent wrench in console and simply drove in the rain, stop and rotate the flat part of the arm ... again...and again until the correct angle was found. Been good since. A new arm may correct also.
HDRocketman is offline   Reply With Quote
Old 07-12-2004, 09:58 PM   #13 (permalink)
titanwild's Avatar
No wiper problem on mine, in town and freeway, over 2500 miles, and lots of rain this spring. Still on the original blades and the wipers are the smoothest I've ever seen, even on a new Lexus.
TitanWild
DeepWater 4x2 KingCab SE,
Big Tow, RF Pop, and Bed Packages, 29Mar04 MDate, Custom Flo-Pro Crossflow Dual Exhaust,
JetTech Traction bars, K&N drop In, OEM Fogs, XD5 9005/9006 Xenon bulbs, Viper 350 Alarm.
titanwild is offline   Reply With Quote
Old 10-10-2004, 05:49 PM   #14 (permalink)
Anyone used PIAA Super Silicone Wiper Blades ?
billaku is offline   Reply With Quote
Old 10-10-2004, 06:03 PM   #15 (permalink)
m4ck's Avatar
Yep I noticed this same thing squeeking and streaking. Not in heavy rain just when its kinda light or medium. It can get annoying. To the point where I just flick the things on every little bit so I don't have to listen to it.
M4ck
m4ck is offline   Reply With Quote
