Any of you with the stock exhaust, do you have a hole in the back of the muffler below the outlet? I noticed this when I was adding oil to the rear diff. (3/4 quart low). The only times that I have seen a hole in a muffler was when it was time to get a new one (starting to rot). It's probably designed this way, but I just wanted to check. Doesn't matter that much, will be replacing with duals in the future. I'm just curious. Let me know.
This is pretty scary with all the low fluid levels in the differentials. I think the dealer has to fill out a check list that they have checked all fluid levels prior to delivery. Apparently alot of dealers cannot be trusted.
Yes, it is normal, it's so condensation can get out.
That's what I thought. Just wanted to be sure. Thanks.
Yah, but my tires only had 33 pounds of air in them. At least they checked them. I pumped them up to about 40 psi.
